[?]: Free software B&R
другие контроллеры
Husanto
Post by Husanto » Sat Mar 28, 2009 8:48 am
Hi all,
I have problem about PLC B&R with Type EX290,
i want to check the problem but i don't a software and the cable,
can any body tell me what software i must to use
and where i can find the software for free??
servodude
Link
Post by servodude » Sat Mar 28, 2009 12:12 pm
Check out the following topic:
http://plc.net.ru/viewtopic.php?t=8605
Husanto
re
Post by Husanto » Sat Mar 28, 2009 6:46 pm
thanks for you information...you know what the download or uploading cable for this PLC??
servodude
B&R Cable
Post by servodude » Sun Mar 29, 2009 3:02 am
If my memory is not too bad, I believe a regular RS-232 cable will do the trick. If you need to make one, there are several posts throughout these forums with details. If you can't find them, just let me know and I will post the pin out.
firstrazor
Post by firstrazor » Mon Apr 27, 2009 10:43 am
If my memory is not too bad, EX290 is not a PLC CPU at all! It is a kind of IO extension adaptor.
olzy1
Re:
Post by olzy1 » Wed Oct 21, 2009 2:05 pm
firstrazor wrote:If my memory is not too bad, EX290 is not a PLC CPU at all! It is a kind of IO extension adaptor.
But you can connecting to cpu and check the extention.
The pins for cable
2-3
3-2
5-5
And connect 4 with 6 on every side. Also you can connect 7 with 8.
