Hi, guys,
can you please advise what have to be done to connect 2 or more PLC having the same IP address to OPC UA server?
Connecting same IP adress PLC to OPC UA server
Re: Connecting same IP adress PLC to OPC UA server
OPC UA protocol work fine through the NAT, unlike OPC DA. So if You need in data acquisition only it is enough.
