Brush-less Motor positioning
привода и частотники
rafa06
Post by rafa06 » Wed Feb 06, 2013 3:46 pm
I am working with a brush-less motor from Control technique, and I am using the inverter Unidrive SP1403. I have to create a simple program using SYPT PRO to command the motor to run until it achieve the desired position. Unfortunately, It is the first time that I will do such a thing, so can you help me with a simple example to start with.
thanks.
