Hi all
i need the the cable pin out to communicate between the pc and micromaster vector drive by using drive monitor, is it similar as the simovert drive cable pin out ???
Regards
Maher
[?]: pin out to communicate pc and Micromaster vector
Re: [?]: pin out to communicate pc and Micromaster vector
Read http://www.ectsales.com/home/180006094/ ... 06SE92.pdf on page 67.
Good luck!
Good luck!
