automator
Post
by automator » Wed Feb 18, 2009 10:44 pm
i want to know if i can how my scada programs will work using a s7 300 simulator or any generla plc simulator that can establish a connection to the iFix software,
is there a plc simulator provided to try iFix programs ?
dibolo
Post
by dibolo » Thu Feb 19, 2009 2:23 pm
you can work but first you have to run the simulation (s7300) and then open the ifix.be carefull what adress you give.check the mission controll or pmon to see the results (no data or com problems).
automator
Post
by automator » Thu Feb 19, 2009 9:11 pm
do you mean the plcsim simulator that comes with step-7 ?
ive heard that it cannot establish a communication with a scada software if its not made by SIMATIC, true?
dibolo
Post
by dibolo » Thu Feb 19, 2009 10:07 pm
no it is not true.you can make at least with ifix and fix32 just take a look
from my computer.
http://plcforum.uz.ua//simulation.bmp
dibolo
Post
by dibolo » Thu Feb 19, 2009 10:13 pm
let me know if its working with you
automator
Post
by automator » Fri Feb 20, 2009 1:28 pm
thanks dibolo
i will let u know what happens when i try it
