[?]: ifix 5.0 KEY
xiaxueyiyi
[?]: ifix 5.0 KEY
Post by xiaxueyiyi » Fri Dec 05, 2008 2:18 am
who has a ifix 5.0 key, share with me, okey?
WH_Mike
Post by WH_Mike » Sun Feb 15, 2009 5:11 pm
Here is key for iFIX 5.0 and some optional tools.
I test it. It work!
Здесьможно взять ключик для iFIX 5.0 и некоторых дополнительных утилит.
Проверял. У меня работает!
wangrenzhi
Post by wangrenzhi » Sat Feb 21, 2009 11:03 am
Only 2015-12-31
automator
Post by automator » Sat Feb 21, 2009 8:28 pm
does this work with iFix 4.5 also?
i have tried it with version 4.5 but it didnt work
any clue?
dibolo
Post by dibolo » Sun Feb 22, 2009 7:54 am
automator wrote:does this work with iFix 4.5 also?
any clue?
no its not working.
WH_Mike
Post by WH_Mike » Tue Mar 03, 2009 4:20 pm
wangrenzhi wrote:????????????????????
Only 2015-12-31
Do you need other data? What exactly? To change data is not big problem... :wink:
I was try to make for 4.5 russian, but not succeed. :cry:
Can try to do for 4.5 english, but can't test it (don't wish to uninstall/install different versions). If anybody need - write here!
Use it only for education and short development period!!!
Things that make a money must be payed!
WH_Mike
Post by WH_Mike » Wed Mar 18, 2009 5:04 pm
lwdzxy wrote:How to change date
There are 3 bytes in license.sys by offsets 0x76...0x78 that define expired date. But with changing them also changed a few else settings (like max I/O points, Historian points and connections and some others). So, there must be changed several bytes accordingly to eleminate unneded affection. I found that for 5.0 - max date with correct displayng day of week and name of month is within of 2034 year. After it date will be shown in iKeyDiag as, for example, "M:12, D:31, Y:2035"
Good luck!
P.S. Is anybody have work license for any russian version iFIX?
lwdzxy
Post by lwdzxy » Thu Mar 19, 2009 3:16 am
underplc
Post by underplc » Wed Jul 01, 2009 5:20 am
wangrenzhi
Post by wangrenzhi » Thu Jul 09, 2009 9:16 am
Runtime 2 hour
rohit02988
Re: [?]: ifix 5.0 KEY
Post by rohit02988 » Fri Jul 28, 2017 5:54 am
Plz share ifix 5.0 key
