[?+]: keygen for Progea Movicon X11
wangrenzhi
Post by wangrenzhi » Sat Apr 12, 2008 12:06 pm
I have Progea Movicon X11
I Need keygen for Progea Movicon X11.
deymon
emulator
Post by deymon » Sun Dec 07, 2008 1:07 am
keygen is bad way. algorithm will change in next build. need dump from hardware key for software emulation.
http://rapidshare.com/files/171040722/E ... ovicon.zip
Movicon 11 Rel. 11.0.1013 Oct 2008 .zip (504 Mb)
P.S. hmmm somebody (admin?) change my link and filename. it not Progea Movicon 11 key emulator. it only tools for make dump from Eutron SmartKey hardware key & make driver from dump (duplicate key).
deymon
Post by deymon » Sun Dec 07, 2008 9:43 pm
i need dump from key 11 version for make full unlimited key
for example http://plc.net.ru/viewtopic.php?t=5740&start=15
send me in PM, please.
frankw
Post by frankw » Tue Dec 23, 2008 6:10 am
If you are using Movicon11, please use the tool
make a dump of the key, and upload it, thanks.
wangrenzhi
Post by wangrenzhi » Sun Mar 01, 2009 5:34 pm
Movicon11 Rel. 11.0.1014
http://www.movicon.info/download/setup/Mov11_Setup.zip
Movicon 11 Build 1015 now available
Movicon 11 Build 1015 for Chinese
http://rapidshare.com/files/204638820/M ... ateCHS.exe
http://rapidshare.com/files/204638820/Mov11_1015_UpdateCHS.exe
wangrenzhi
Re: emulator
Post by wangrenzhi » Sat Mar 14, 2009 2:00 am
deymon wrote:keygen is bad way. algorithm will change in next build. need dump from hardware key for software emulation.
Hi deymon
Emul_key_for_Progea_Movicon.zip is Ver1.01
I have EuDMP V3.07,
http://rapidshare.com/files/208960968/EuDMP_V3.07.rar
How Will Make Eutron.dmp to Eutron.sys For V3.07?
think
deymon
Post by deymon » Sat Mar 21, 2009 3:08 am
hi China brother
your link not work
direct link for this tool http://www.brstudio.com/Keys/eudmp.rar
it's different programs and compare versions not correct
deymon
Post by deymon » Thu May 21, 2009 9:41 pm
wangrenzhi
Post by wangrenzhi » Fri May 22, 2009 4:45 pm
this address download is 11.0.1014(546Mb)
d'nt download 11.0.1016 or 11.1 Bata
mech962784
Re: [?+]: keygen for Progea Movicon X11
Post by mech962784 » Thu Oct 29, 2009 10:09 am
Dear Friends
I have installed Movicon on a PC that does not have a Parallel port, so the license is not working and it is showing me that the serial number is 0.
does anybody have a solution for me?
DbIMok
Post by DbIMok » Thu Dec 10, 2009 9:50 pm
mech962784: try install parallel port driver without real hardware.
McAlexU: for 10 only:
http://rapidshare.com/files/172725925/mov10m.zip
http://rapidshare.com/files/237614412/mov_drv_lic_code.zip
sometimes not working
Where i can find parallel port driver, so i can install it ?
Start - Control Panel - Add new hardware
Add new device - Manual - Ports - Parallel port
wangrenzhi
Post by wangrenzhi » Fri Dec 18, 2009 4:48 am
Vansdan
Post by Vansdan » Thu Jan 14, 2010 10:17 pm
Hello
is there any crack/serial for Progea Movicon 11 available or just for version 10.x? At the moment I´m a little bit confused about the conversation in this thread.
Where can I find a crack/serial?
Thank you for your answer in advance
Vansdan
DbIMok
Post by DbIMok » Tue Jan 19, 2010 1:39 pm
:search:
wangrenzhi
Post by wangrenzhi » Tue Feb 23, 2010 11:19 pm
Movicon 11.1 Ver 1055.
http://www.movicon.info/download/setup/ ... _Setup.zip
Please Crack or Keygen Help me.
DbIMok
Post by DbIMok » Thu Sep 02, 2010 6:10 pm
emulator for 11 at the end of this topic:
viewtopic.php?f=14&t=5740&p=37554#p37554
Movicon 11.2 Rel. 11.2.1083 Oct 2010 (620 Mb)
