Intouch Tags
Aztech
Intouch Tags
Post by Aztech » Mon Jan 26, 2015 7:03 pm
I have got an issue. Does anybody knows if it is possible with Intouch to read a bit inside a byte tag like in WinCC? Example: I have a tag DB1.DBB2, but I only need to read the status of DB1.DBX2.5. How it is possible to do without creating a discrete tag?
Thanks!
cmos
Re: Intouch Tags
Post by cmos » Tue Jan 27, 2015 5:49 pm
in expression you can use for example tagname1 AND 2**5
where tagname1 is the tag of DB1.DBB2
read this http://platforma.astor.com.pl/files/getfile/id/3887
Aztech
Re: Intouch Tags
Post by Aztech » Tue Feb 03, 2015 3:02 am
Thanks a lot, Cmos!
I think, you meant tagname1 & 2**5 and it works.
But now I have got opposite question. Is it possible to set/reset bit in byte tag?
apilife
Re: Intouch Tags
Post by apilife » Tue Feb 03, 2015 9:05 pm
You can use bit fields with integer tags.
Thus, with an integer tagname "MyTag", MyTag.00 is the least significant bit and MyTag.31 is the most significant bit.
You can read or write the bit field :
IF NOT MyTag.05 THEN
    MyTag.05 = 1;
ENDIF;
