Atals copco Elektronikon 1900 0700 08 screen problem
we have atals copco air compressor it is sceen Elektronikon 1900 0700 08 screen give alarm system failure 11 how to solve this alarm.
Re: Atals copco Elektronikon 1900 0700 08 screen problem
thank you very much aakodi but also I need to know the meaning of system failure -104 and if you have manual for this controller please share it.
Hi all,
we have a problem with an Atlas Copco compressor and it has ELEKTRONIKON PLC and on the display there is nothing but this number "100100000000".
Can someone help me please to understand what does this mean and how to resolve it.
No one is able to help me about this?
Morning all has anyone found a solution to the error code on the Elektronikon 100100000000.
I hav got this same error on our Compressor and am struggling to find a solution to the error.
Any help would be greatly appreciated.
Hello!
Error 200 occurred, it was reset, and the compressor started and started.
Then he stood for a while and when turned on, writes 110100000000 on the screen and does not respond to buttons.
Maybe new information appeared and someone solved this problem?
you need dump file for eprom and time keeper with correspond the serial number of comperessor,and nobody have software for doing it else atlas copco company.this software is special that all serial numbers of atlas comperessor can with reprogram by using it.
For system failure see the two link below:
http://comprforum.ru/viewtopic.php?f=28&t=954
https://www.automatenfreunde.de/downloa ... chluss.jpg
