opc server for acm800 connection with scada intouch
scarebyte
Post by scarebyte » Thu Feb 28, 2013 12:42 am
I have an application running on compact control builder, using softcontroller. The opc server for acm800 is running and is connected to the controller. I can see the items using free opc software explorer. For example the item "Photo_cell" is under Applications.Application_1.Program2.Photo_cell.My question is what "node name", "application name", "topic name" parameters I should put in wonderware intouch for read the opc items. Or which other scada software I could use?
Thanks.
giffgis
Contact:
Re: opc server for acm800 connection with scada intouch
Post by giffgis » Fri Mar 01, 2013 1:23 am
If the OPC is on the same PC, the field node name must be in blank, if other pc you write the IP o the target computer name.
Intouch need a connector named FSGateway. It link the OPC with Suitelink, the wonderware communication protocol.
If already install FSGateway, The application name is FSGateway. then you are configure FSGateway via System Management Console.
What inotuch version have installed?
This link may be help http://www.plctalk.net/qanda/showthread.php?t=37100
