[?]: BACK UP KEY for a ABB digivis scada software
Hello every one
I need some help, I need to back up a USB license, for a ABB digivis scada software
please any advise
please any advise
Re: [?]: BACK UP KEY for a ABB digivis scada software
Digivis using HASP dongle, so you can try to dump the dongle as it is described in the topic below:
viewtopic.php?f=7&t=13472&start=50#p46338
Just skip the 9th step.
P.S. Upload your dongle dump (.REG or .FST) on forum when finished.
hello just started again with the deal,
I am not sure wich file downlad on the hard lock amulator
on this site
http://www.eplan-eb2.ys168.com/
on this site
Some thing happen and I can`t see any thing
on the usb stick, but i think the license is there,
only the pc with the software makes the usb work
any other pc, dont even sees it as drive,
any idea?
any idea?
But HASP dongle should not be detected as a drive...
Dongle usually requires a driver to be installed to the system. Driver software supplied with DigiVis.
Linkinx64
I got spoke to digi vis people, and they are sending me the file,
now the question is, with this file installed on the operations pc, should I do the procedure to back up the usb,
or should i back up first with the procedure you said
What kind of file they're sent? I don't know it.
Backup USB first and upload to let us see it
hi
they will send a file that have to be install on the pc with tha aplication (scada) to work, the deal is I have try to run TORO and I can`t see any thing,
I guess with this file will make it work, because I install the usb on the aplication and it does not work,
do you think. I need to back it up when I get this file?
What is a file that makes Digivis working can be?
Digivis is activated by insert dongle to the USB hole or LPT port. No additional files required.
If this is not "License mode" patch... I have no idea what "digivis people" can give you else.
Upload when you get it. A very interesting!..
Linkin64
How can I up load the file i got, to see if you can find some thing
Hello here is the file they send me
I hope you can help me
http://www.4shared.com/file/EK09K9wN/F2k.html
