[REQUEST] Switch2Citect
af.naderi
Post by af.naderi » Sat Sep 04, 2010 9:27 am
Hi every body,
Does anyone has Switch2Citect ?
http://www.citect.com/index.php?option= ... temid=1386
Switch2Citect is a software conversion tool that helps you to migrate legacy HMI/SCADA software systems to the world-class CitectSCADA software with less risk, cost and effort.
Switch2Citect also gives you the ability to have full control over the conversion process so that you can improve your legacy system by adding new functionality, improving the maintainability and incorporating corporate standards.
Switch2Citect can migrate around 75% of the World's HMI/SCADA systems
Please share.
af.naderi
Re: [REQUEST] Switch2Citect
Post by af.naderi » Sun Sep 05, 2010 5:56 am
hi, thanks for link, but my problem is that Switch2Citect only open *.draw file format and then export to citect.
for example if i want to export my intouch application to citect, i must do some things and then send my files to citect.
after this steps they send *.draw files to me to export to citect.
I want know *.draw transport process.
Could anyone help me?
