[Link] Canvas + Kepserver [Reverse Engineering help needed]
Str3atWarrior
Post by Str3atWarrior » Mon Dec 14, 2009 8:23 am
Here is a link for Canvas 3.30 by Eaton Cutler-Hammer :
Link_is_Dead :(/C ... 0.Link_is_Dead :(
You'll also need KepServer ePro (or any other version, tried and working with EX version cracked). Here is a link for ePro version :
Link_is_Dead :(/K ... r_ePro.rar
Link_is_Dead :(/KEPServer_ePro.rar
Please note that Canvas is in Demo mode for 30 days, and KepServer ePro is also in demo mode that only allow you to run it for 2hrs before needing to reload it. I suggest installing EX version with cracked drivers, and just inject the Eaton Cutler-Hammer drivers if needed. I'm trying to do some reverse engineering on LicenseEPro.exe to build some kind of keygen for Canvas, but i've never done anything like that before. So if someone have some knowledge in reverse engineering, and would like to help, it'd be appreciated!
For thoses who don't know Canvas, it's kinda like Cimplicity by GE Fanuc, but i like this one more. It allows you to interact with lots of PLC brands by designing a workable interface over a computer. We have a registred version at my job and it simply rocks! We are managing lots of distants 90-30 with this. But i'm still kinda new to thic PLC and HMI world, and 1000$ a licence for Canvas and 2500$ a licence for KepServer is way too much for my budgets with the kids and wife :roll:
Have fun with this one!
Str3atWarrior
Re: [Link] Canvas + Kepserver [Reverse Engineering help needed]
Post by Str3atWarrior » Mon Dec 14, 2009 11:18 pm
Found a way to transfert the key we had at shop into any computer without too much trouble. I'm still in the process of learning reverse engineering to make a keygen, and i will post it as soon as completed!
As far as i got, i now know for sure that they serial must be a 5 digit numerical for Canvas, so it souldn't be too much trouble. As for KepWare OPC - DX Application and KepWare OPC Server Application, no job have been done at the time to crack those. As soon as i'm done with Canvas, i will move to them one by one. But don't expect too much, never done that before ;)
Str3atWarrior
Post by Str3atWarrior » Wed Dec 16, 2009 8:24 pm
So have anyone tried it yet? What do you think of it?
Str3atWarrior
Post by Str3atWarrior » Wed Feb 10, 2010 2:38 am
Update 09/02/2010
The serial for Canvas, Kepserver and other is truly 5 numerical long. I've found a way to register all of them using a bruteforce program that try every possible combinaison. With my programmation laptop, i managed to get all the keys under 2 hours.
If someone is interested in the name of the application, please drop me a pm. I don't want to publicly tell how i've done this incase some Eaton Cutler-Hammer representative browse this forum and find a way to bypass this.
Str3atWarrior
douyi
Post by douyi » Wed Jul 24, 2013 2:29 pm
Hi Str3atWarrior,
Do you mind PM your canvas key finder? I'm looking for it for a long time, thanks a lot!
Douyi
Binary01
Post by Binary01 » Sat Nov 22, 2014 4:46 am
Str3atWarrior...can i get a copy of kepserver/ I have been looking for it a long time..
mytom123
Post by mytom123 » Tue Dec 30, 2014 8:46 am
Str3atWarrior
Can i get a copy of kepserver, I have been looking for it a long time too.
Wjmdtt
Post by Wjmdtt » Fri Oct 20, 2023 4:47 am
Share the Eaton canvas Key, or panelmate software! Thank you!
hakerbitz
Post by hakerbitz » Sat Dec 16, 2023 7:45 pm
To make this software "work". Find on the Internet "Ida Pro Adv EditionTDM.exe". install it.
Open IDA. Hit New, open one of the files named "LicenseEPro.exe" usually at
C:\Program Files\Cutler-Hammer\Canvas 3.31\System\LicenseEPro.exe
C:\Program Files\Cutler-Hammer\Canvas PC Runtime v3.31\System\LicenseEPro.exe
leave the open options as default, hit yes for debug information
hit debugger-> select debugger-> Local Win32 -> press ok
Next to the file menu, Hit Jump -> Jump to address - >Type 409D6E ->click ok
it will bring your cursor to a line that reads mov ecx, [esp+8+Str]
Press F2, it will highlight the line in RED - Press F9 to run in debug mode
if you get a debugger warning Hit Yes.
Software registration will appear. hit initiate activation on all the options, and hit ok on the warnings,
Click a line with License temporary, leave activation key as 0 and hit apply activation.
The debugger will detect this and freeze the program,
It will show the valid activation key in the last 4 digits of the EAX register in hexadecimal.
write this down then press F9, and change tabs back to software registration, hit ok on invalid.
convert the 4 digit EAX hex value to decimal using calculator in programmer mode. or google it online
use this value as the activation key. if the debugger stops you again, just press f9 to continue.
mic drop
