[?]: Intouch and ArchestrA
kshok
Post by kshok » Sun Sep 27, 2009 11:23 pm
i started to read InTouch® HMI and ArchestrA®Integration Guide,
where can i fine InTouchViewApp object to use ArchestrA?
i only have intouch v10,do i need to another software to use ArchestrA ?
thanks in advance
khongbaogio
Re: [?]: Intouch and ArchestrA
Post by khongbaogio » Thu Jan 21, 2010 7:15 am
U need to install Intouch Application server. and it doesn't work on window XP platform, it works on window server only.
af.naderi
Post by af.naderi » Wed Jan 27, 2010 5:30 am
it 's not true. installation requirement for Aplication server 3.1 is:
1- windows xp sp3
2- sql server 2005 sp2
you must install Application server + InTouch on same computer. when you do it, and run InTouch, in menu bar you can see a new
icon named : ArchestrA IDE. click it.
create a new galaxy on ArchestrA IDE.
follow instruction on InTouch® HMI and ArchestrA®Integration Guide file.
regurds
DelSnos
Post by DelSnos » Thu Jan 28, 2010 4:54 am
Greetings brothers on work!!!
1. Whether there are for you documents or courses (training) on application server 3.0?
2. At registration on https://www.pacwest.wonderware.com/web/Register.aspx a site asks ID Wonderware. Whether there is for someone data for registration filling?
Thanks for the help!!!
Russian wrote:Доброе время суток, уважаемые форумчане
1. Столкнулись с проблемой по Application server 3.0. В срочном порядке приходится изучать его! Может ли кто-нибудь скинуть дополнительные манулы или еще лучше курсы!Как известно, в бесплатном исполнение докментации нет, а то что есть это тока поверхностный уровень!
2. При регистрации на https://www.pacwest.wonderware.com/web/Register.aspx необходимо знать ID продукт Wonderware! Может ли кто то владеть и поделится такой информацией??
Спасибо! Надеюсь на помощь!
af.naderi
Post by af.naderi » Tue Feb 02, 2010 6:01 am
hi DelSnos,
you don't need wonderware website,
download Wonderware video training dvd (u can find it in plc.net) and follow trainings about application server.
aslo u can read pdf files (this files made by installation Application server) and find many things.
DelSnos
Post by DelSnos » Fri Feb 05, 2010 1:49 pm
af.naderi wrote:hi DelSnos,
Thanks!!! I have already manuals application server on an official site. The problem was in registration. Registration (https://account.wonderware.com/idm/publ ... gistration) does not work in a browser Opera!!!
