MODBUS TCP IP IN CONTROLLOGIX
NPNPAVAN
Post by NPNPAVAN » Sun Jul 21, 2019 1:12 pm
Dear All,
Anybody can help on MODBUS TCP IP IN CONTROLLOGIX?
I have to read 30 Slaves data. And i am having 1756-L72 controller and 1756-EN2TR.
I have checked the sample code, which is downloaded from Rockwell Sample codes But with that I can read only 4 slaves Data only.
Sample Code: https://www.rockwellautomation.com/sear ... king=false
Thank You.
sandmanplc
Re: MODBUS TCP IP IN CONTROLLOGIX
Post by sandmanplc » Tue Aug 27, 2019 5:26 pm
Hi
If you download the sample code, there are 2 manuals on the zip where you can read that the code only accept a maximum of 4 connections to unique IP address.
However, the manual also says that you can change this limitation modifyng the application (possibly on the tags).
Good luck!
