migrate from from panel view 550 to panel view plus 600
omark
Post by omark » Wed Jan 11, 2017 11:46 am
Hi everybody
I need to migrate my project in panel builder (panel view550) to panel view plus 600.
Can someone help me please?
tkx
Ryzhij
Re: migrate from from panel view 550 to panel view plus 600
Post by Ryzhij » Thu Jan 12, 2017 5:22 pm
"for the labourer is worthy of his hire"(Luke 10:7)
What do you suggest?
omark
Post by omark » Fri Jan 13, 2017 10:20 am
Ryzhij wrote:"for the labourer is worthy of his hire"(Luke 10:7)
sorry I dont interstand, what do you want to say?.
Ryzhij
Post by Ryzhij » Fri Jan 13, 2017 5:52 pm
You really do not understand what serious work requires a serious approach, and must be paid?
How much are you willing to pay for this work?
wildpikachu
Post by wildpikachu » Tue Jan 17, 2017 9:23 am
Hi Omark,
In simple terms.
1)Save the panelBuiler32 file as a .PBA file.
2)import the file into factoryTalkView by creating a new project and selecting import.
3)pay attention to any errors listed when the conversion completes and correct them.
4) check each page to confirm operation and styles - pay special attention to text size and numeric entry points.
5) create you project path for RsLinx Enterprise - make sure that your DF1/DH485/DH+ settings are correct.
6) compile the application and download to your new panelView Plus 6 600
I assume you meant the panelView Plus 6 series HMI and not the panelView Plus series as the standard panelView Plus series is no longer available (at least here).
http://literature.rockwellautomation.co ... _-en-p.pdf <-- link to the migration guide
http://literature.rockwellautomation.co ... _-en-p.pdf <-- link to the catalogue migration guide.
Cheers
omark
Post by omark » Wed Jan 18, 2017 12:39 pm
wildpikachu wrote:Hi Omark,
In simple terms.
Cheers
Hi wildpikachu,
Thank you so much for your answer
The problem that i had is how to open panelbuilder file in factoryTalkView but after your explication i understand and i well do that after download and install factoryTalkView
thank you again
omark
Post by omark » Wed Jan 18, 2017 12:44 pm
Ryzhij wrote:You really do not understand what serious work requires a serious approach, and must be paid?
I’m ok with you
But normally there some Tricks in ALLEN Bradley software can do this work.
