I would like to know suppose I recieve 123456 in ascii format from application and is transferred to PLC DINT file N123, N124, N125 (2 digits each; 12 in N123, 34 in N124, 56 in N125). How can I make this number show as 123456 decimal and '123456' string in the plc (i tried DTOS but it shows decimal value of the ascii)
The data I am recieving is only integer values (0 to 9 in ascii) but cannot be changed as the application is protected. I want to know for CLX and PLC5. Help appreciated. Thanks
[?]: ASCII and string
Re: ASCII and string
I have already built such routine to convert int to string (for contrologix)
You can find below the link for download the routine.
To use this routine you have to add a tag in controller tag:
Type : String
Value : '0123456789'
https://mega.co.nz/#!VRQGGL5A!SDEUYTiOo ... 64tXZ2H-PE
For you application, you have to concat the 3 partial strings into 1 final string.
You can also convert string to Dint (CLX only...)
You can modify this code for PLC5
Best regard
Type : String
Best regard
Re: [?]: ASCII and string
Thank you dehell...i will test it in 2 days...help appreciated.
I get error when I try to import "failed to import .L5X. The specified L5X does not contain a Routine export". My version is 20. I think you are using 16. Could this be the reason for this error?
Yes this routine have been created with RSlogix 5000 V16...
You can find below the pdf file of the routine
https://mega.co.nz/#!EURGhLIR!STqOJjWcG ... l0mCR2a8jY
