hello
i have controle system consist of main plc type plc 5 connect with porfibus scanner type SST_PFB_PLC5 this scanner has 7 node ADAPTER MODULE PROFIBUS DP type 9900_HSM_APB used to control 7 gate work with special sequence the problem that one node of 7 adapter module has no communicate with the profibus scanner and there is alarm on the scanner but the other 6 node work good i change this node with another work node adapter it work good , so the communication cable work good .
i change the adapter module with another new one different in type 1794_APB but the porblem is still , so i think the new module need to configurate it ,the question how i config it , and if the programe removed from the old one also how i can config it .
please any help it is important
[?]: adapter profibus dp 1794_APB
Re: [?]: adapter profibus dp 1794_APB
any help please
