[?]: rslogix / rsemulate compatibility
phatbear
Post by phatbear » Tue May 15, 2012 10:14 am
Hi All. I am getting started PLC. I have RSL5000 v20 and RS EMU V19. Environment is configured and everything is visible in RSLink AB_VBP virtual backplane. When I try to go online, I believe I am seeing version compatibility issues (V20 will not talk to V19.)
Can someone confirm.
Also, I am unable to locate RS EMU V20. Can anyone link?
Thanks for the help.
neuhauser
Re: [?]: rslogix / rsemulate compatibility
Post by neuhauser » Sat May 19, 2012 12:58 am
A higher version of 5000 will not run on a lower version emulator - firmware differences between revs.
You'll need to install v19 5000 also and convert the project to 19 to emulate. Multiple versions can be installed at the same time.
