Just wanted to know how shall I locate the error that causes the fault of 1747-SDN/B?
If there's any way to know the error that causes the fault at the scanner?
Because from the information that I got from our client, even if the said scanner is showing fault, they are still using the said device and is performing well.
Do I need to have any software to see the scanner error?
Request: AB 1747-SDN Scanner Module
Re: Request: AB 1747-SDN Scanner Module
1747 SDN module have 2 leds and a numeric display.
Use the 1747 SDN manual to understand the code show by the scanner (go to page 90)
http://literature.rockwellautomation.co ... _-en-p.pdf
RSNet worx for DeviceNet software may help you to solve your problem.
Best regard
Best regard
