[?]: MSG Instruction Help
cuongvcs
Post by cuongvcs » Fri Jul 29, 2011 8:58 am
I have a small problem.
I have 1 SLC 1747-L553C and 1 controllogix Controller .This PLC communication through ErtherNet.
Help me how to write the communication between them through ErtherNet.
If you can give me some specific examples, the better the guide.
thank and best regards. (sos) (sos) (sos)
Ryzhij
Re: [?]: MSG Instruction Help
Post by Ryzhij » Fri Jul 29, 2011 5:55 pm
Do you have the Logix5000 Controllers Messages Programming Manual (in English) or same manual in Russian ? (dlink)
Also the SLC 500 Ethernet Quick Start (in English) may be help you.
hai_api
Post by hai_api » Sat Jul 30, 2011 7:24 am
Hi Ryzhij !
I try to do follow in manual but sitll can't .
the MSG intruction in my program only with control block lenght 14 , with ethernet it must be 51 .
i do all ways but still not. (h)
and in Target device only have 500CPU / 485CIF / PLC5 / MODBUS , no more but i wanna to send massage to control logix PLC (how can I do ?)
Same with this in RS logix 5000
now i use Rs logix 500 V8.4
please help me.
Can they communication or not?????? :shock: :shock: :shock:
Ryzhij
Post by Ryzhij » Sat Jul 30, 2011 11:05 am
Tray read this discussion also http://forums.mrplc.com/index.php?act=ST&f=1&t=14976
I hope it can help you
PS: Sorry, but my Tec-connect numbers is absolved now
cuongvcs
Post by cuongvcs » Mon Aug 01, 2011 1:21 am
You can give me some specific examples .
thank a lot.
