[?]: Not found RSLinx OPC server .
I have small problem , it's like this . when I want connect RSLoigx 5000 V17 with Factory Talk View Machine but can not connect because i did not find RSLinx OPC server .Please help me .
Best Regards
Best Regards
Re: [?]: Not found RSLinx OPC server .
Have you install RSlinx enterprise?
thank you ! i try to reinstall.
Best Regards
Best Regards
I have tried reinstall RSlinx enterprise and Factory Talk but with no results.Hope you can help me , thank you
What do you want to make? Connect FTalk view studio ME projet to RSlogix 5000 project?
Give us more details!
Not found RSLinx OPC server when connect between RSlogix5000 V17 with Factory Talk view machine
I still connect previously normal ,but on a nice day ,it automatically stop that they can never connect.
In new project factory talk view studio ,I selected Add new server and choose OPC data server .OPC data server properties diaog appear .In General tag is project name , OPC server name (ProgID) I select browse and select an OPC data server .
It is at first RSLinx OPC server .....etc. but now it has only localhost and i do not choose.
Please help me.
PS : But with RSView 32 is running normally.
Please help me.
Now I have done already. Thank you for your help
good luck and Best Regards
HI, I also have a same trouble.I can not find any OPC server on local host.I read that cuongvs solved this. Can you guide me clearly? My system is WinXP SP3.
There was nothing where also greatfriend. I also tried many ways but with no results, finally i reinstall again my compute world is.
I also find out where the test causes.
Good luck.
