I've installed Rslogix5000 and i tried to create a new project but when i tried to configure the I/O i can't add I/O module ( but i can add communication module ).
I don't know what happen with my software because my software is a license software.
Please help me to solve that problem.
[?]: Rslogix5000 problem
- Contact:
Re: [?]: Rslogix5000 problem
I set up a new project like you show.
I had no problem adding the modules you show.
I'm using V17.
You want to re-install again.
Good luck
I'm using V17.
Good luck
I creat a new project like you show = no problem.
I'am using Windows XP-PRO with RSlogix5000 V16.
I am not sure that RSlogix 5000 run very well under Windows VISTA
Best regards
Best regards
You can download RSLogix 5000 V17 in this topic. if he used the lisence key , try using RSLogix v17. I also use that mind.
run the nomal.
best regards
run the nomal.
best regards
- Contact:
hihi I've just solved my problem! It's just about the profile of modules are not correct so the software can't create a new module. Finally, you just have to reinstall the software or the profile of modules!
I think the best way is re-install.
And I remember the laster version with v17 couid be installed in visita.
