hi
how can i setup a password for cpm2a plc
please help me
[?]: how can i set password for cpm2A
Password CPM1A
You can use FUN function .....with code
AR10.01
----||----------------------------------------------- |FUN(41)|
|#5F41 |
|#1234 | ---> pass(1234)
AR10.01
|#5F41 |
Re: Password CPM1A
In your procedure has the little mistake ......Husanto wrote:You can use FUN function .....with code
AR10.01
|#5F41 |
Because in Omron, Fun49 is the system hypothesis function, uses in establishing the system password, but is not Fun41 which you enumerate.
But very more importantly: After the establishment finished, downloads, must start PLC certainly to be able to cause the hypothesis to become effective.
Above ~~~
password cpm2a
Yes You right, sorry i means Fun49. thanx you for you correcting.
