[?]: CQM1H & HAKKO V706
CX-One, CX programmer, NTST, Syswin ....
dikobraz
Post by dikobraz » Sat Sep 11, 2010 3:38 pm
Hello! I work with CQM1H CPU51& HAKKO V706.
After using few times simulator in V-SFT5 for HAKKO cannot connect with CQM1H CPU51 (shown Communication error).
I check comm parameters, cables etc...
Any help? Thanks!!
cvlsam
Re: [?]: CQM1H & HAKKO V706
Post by cvlsam » Sun Sep 12, 2010 12:13 am
Your wiring diagram is whether correct?
The communication actuates whether to have chosen Sysmac C?
Wiring Diagram:
Regards
dikobraz
Post by dikobraz » Sun Sep 12, 2010 6:46 am
Yes, my cable is correct. I check cable, comm parameters but stil have problem. Any more sugestions?? Thanks!!
Homeroid_BL
Post by Homeroid_BL » Sun Sep 12, 2010 2:26 pm
Checked serial mode (232, NT, 1:N NT...)?
dikobraz
Post by dikobraz » Mon Sep 13, 2010 5:58 am
Yes I cheked that, and thats OK. This problem hapened after I use simulator in V-SFT 5 several times... I chek everything but I stil have problem... Any other sugestions?? Thanks!!!!!!!!!!!!!!
cvlsam
Post by cvlsam » Mon Sep 13, 2010 8:45 am
dikobraz wrote:Yes I cheked that, and thats OK. This problem hapened after I use simulator in V-SFT 5 several times... I chek everything but I stil have problem... Any other sugestions?? Thanks!!!!!!!!!!!!!!
If your cable is no problem with the settings, uncheck USE Simulator download option.
If you still can not solve your problem, then the first test about your hardware is working.
Regards :D
dikobraz
Post by dikobraz » Mon Sep 13, 2010 3:21 pm
Thanks but I stil have problem.....
