Запуск WINCC из автозагрузки
Katerina8989
Post by Katerina8989 » Tue Aug 20, 2019 5:52 am
Здравствуйте!
Подскажите пожалуйста, как создать ярлык для запуска Wincc Runtime? Хочу ярлык добавить в автозагрузку. :)
Info
Re: Запуск WINCC из автозагрузки
Post by Info » Tue Aug 20, 2019 7:03 am
Какое именно WINCC ? Их тьма (h)
(sfaq) https://support.industry.siemens.com/cs ... c&lc=ru-RU
(sfaq) How do you set up Autostart for WinCC v7.* ?
You can use the "Autostart" function to start WinCC with a specific project when the computer starts up.
  • Set up Autostart with the "Autostart Configuration" tool without SIMATIC NET
    Set up Autostart with the "Autostart Configuration" tool without SIMATIC NET in the WinCC Service Mode
    Set up Autostart with the "Autostart Configuration" tool with SIMATIC NET
(sfaq) How do you configure the WinCC Autostart for WinCC flexible Runtime?
Start modes:
  • Via a shortcut with the project in the Autostart directory of the Windows Start menu.
    Via a shortcut with Runtime in the Autostart directory of the Windows Start menu and specification of the project to be started in the configuration file.
    Via the "Settings" dialog of the WinCC flexible Runtime Loader (see also Entry ID: 29054992).
    Via the configuration console of SIMATIC NET if editions 2005, 2006 or 2007 of SIMATIC NET are used.
