[?]: How to download the OP pages to C7 with out serial port
I have a Siemenes C7-633P PLC and my new laptop doesn't have serial port anymore. just USB.
How am I supposed to download the OP pages to C7 with out serial port???
I tried one of Usb to serial (Prolific or something like that) converter, but still no success. Does anybody have any comments :?:
and another thing. with C7 PLCs which has a DP interface, can I download the pages via PC-Adaptor being connected to profibus conection and assign download prefrence to MPI/DP??
When I say that it is possible to download project to C7 I mean that I use WinCC Flexible (2005). If you want to download WinCC Flex project to C7 then you have to insert PC station (assign profibus interface in assignment table and give unique profibus address to PC) and in Transfer mode of WinCC Flex choose Enable Routing for MPI/DP mode. Connect PC Adapter to profibus port of C7. Then all works. With ProTool I have no expirience.
Regards
Regards
I also have one DIGITUS USB to Serial adapter (DA-70146). Price is around 10EUR. In Control Panel/System/Hardware/Device Manager you can see under Ports(COM&LPT) that OS see this virual port as real one (see Digitus manual). Did you try to dowlnoad project with desktop PC which have Serial port. Maybe you have some other problem.
