[LINK]: SIPROTEC DIGSI 4.83/4.85/4.89
Maxx
Post by Maxx » Thu Oct 16, 2008 8:11 pm
Please post a link to download DIGSI 4.8 or 4.7
Software for Configuration of SIPROTEC 4 Devices
http://siemens.siprotec.de/download_neu/index_e.htm
I have v4.4, but need new
viewtopic.php?t=8637&highlight=digsi
Russian wrote:Коллеги, срочно! Нужен DIGSI 4.8 или 4.7.
Нашел здесь v4.4, к сожалению не подходит.
Link
DIGSI 4.81 and 4.82
Post by Link » Tue Feb 10, 2009 4:29 pm
I've DIGSI 4.81 and 4.82 but each version had bigger size about 1GB.
I can't share to you due to my net very slow :cry: :cry: :cry:
If you can download by bit torrent maybe posible for me. :) :o :lol:
I'm sharing DIGSI4 update V4.82 on the Torrent link as following:
http://www.demonoid.com/files/details/1 ... 1235029886
Serial 13779-0127-10639
Enjoy download
Link
Post by Link » Sat Feb 21, 2009 8:36 pm
SIPROTEC DIGSI 4.82
8x45000 KB + 1x26472 KB
Links:
rapidshare [dead]
SIPROTEC DIGSI 4.82 Devices
13x45000 KB + 1x17486 KB
Links:
rapidshare [dead]
serial number :13779-0127-10639
Klong
Post by Klong » Tue Feb 24, 2009 7:06 pm
Umencho wrote:Hello
You can use old one viewtopic.php?t=6201&highlight=digsi
I used and finish with installation successfully. But later after restart the PC and start the program, receive message that needs ALM. I used my home notebook and there I haven't this software. I think that this isn't be usefull but you can try and post the result.
ALM mean Automation License Manager.
If it's posible please install WinCC first after that Digsi.
Please check ALM service by run services.msc, ALM should be started.
I want to see receive message picture, please capture your screen display.
laboul2
Post by laboul2 » Thu Feb 26, 2009 11:20 am
you can used this serial number :13779-0127-10639 (for digsi 4.7) with digsi4.82 normally without problem
thank you a lot, great job
Umencho
Post by Umencho » Thu Feb 26, 2009 5:37 pm
Hello
[ALM - A... license man...] :wink: Ok.
Is this works without WinCC/
Maxx
Post by Maxx » Mon Apr 06, 2009 11:32 am
Thanks to all very much.
I've got DIGSI 4.8, but in this version they use CFC 6.1. Do they use CFC 7.0 in this one?
samedsoft
Post by samedsoft » Mon Jul 27, 2009 11:54 am
DIGSI PROFESSIONAL + IEC61850 is needed!!!
Also licence and serial numbers if necessary
Link
Post by Link » Sat Jun 05, 2010 7:06 am
SIPROTEC DIGSI v4.83 (MultiLanguage)
12*100.000.000 + 11.626.780 bytes
rapidshare [dead]
Hotfix 2 for / zu DIGSI 4.83 http://siemens.siprotec.de/download_neu/index_e.htm
http://siemens.siprotec.de/download_neu ... 83_HF2.zip
SN: 13779-0127-10639
Image Torrent http://rutracker.org/forum/viewtopic.php?t=2967350
Direct link for your torrent client
rapidshare [dead]
Documentation
Russian wrote:Digsi 4 управляющая программа для устройств SIPROTEC 4
DIGSI 4 удобная и дружественная к пользователю программа для конфигурирования и установки уставок в устройствах защиты.
При помощи редактора дисплея Вы можете полностью свободно нарисовать первичную схему присоединения и управлять коммутационными устройствами из реле Встроенные средства позволят Вам проверить токовые цепи устройства, монтажную схему и передачу сигналов для защиты и системы управления подстанцией. Это позволит сократить время ввода в работу При помощи редактора CFC можно устанавливать связь между сигналами и функциональными блоками в графическом виде для реализации пользовательских логических функций
При помощи программы DIGSI Remote 4 можно установить связь из офиса через модем с реле зашиты SIPROTEC 4 и управлять реле так, как если бы Вы находились на подстанции
Русский интерфейс
http://siemens.siprotec.de/download_neu ... _A1_RU.pdf
http://siemens.siprotec.de/download_neu ... 003_RU.pdf
http://siemens.siprotec.de/download_neu ... 004_RU.pdf
mohammed yousif
IEC 61850
Post by mohammed yousif » Thu Jun 24, 2010 2:45 pm
I have digsi software vesion 4.82 when I try with the exercise fo IEC61850 and when I insert new object , IEC61850 station and then go to its object properties, appear message on computer screen tale me that " the required license is not installed " . and then I cannot continuouse with this exercise . please can you help me to solve this problem ?
with my respect
laboul2
Re: [LINK]: SIPROTEC DIGSI 4.83
Post by laboul2 » Sun Jun 27, 2010 4:32 pm
hello, request DIGSI 4.83 UPLOADED on narod.ru if possible; thank's
focus
Re: IEC 61850
Post by focus » Tue Jun 29, 2010 5:32 am
mohammed yousif wrote:I have digsi software vesion 4.82 when I try with the exercise fo IEC61850 and when I insert new object , IEC61850 station and then go to its object properties, appear message on computer screen tale me that " the required license is not installed " . and then I cannot continuouse with this exercise . please can you help me to solve this problem ?
with my respect
You have to uninstall digsi, and install with this code 10355-0255-58139 (pgood)
segamega
Post by segamega » Fri Sep 10, 2010 2:42 pm
When i start digsi only this window appears. What's wrong?
Post by CoMod » Fri Sep 10, 2010 3:58 pm
I have tested with clear VirtualBox - it work Ok.
mdanijel
Post by mdanijel » Thu Nov 04, 2010 9:11 pm
Hello, I have installed DIGSI 4.83 with given serial number, but when starting it asks for valid license key
(Message: "No valid license key found. Please install valid license key")
. Did I miss something?
Also installed SP1 and Patch1, nothing changed.
Thanks!
samal_jspl
Post by samal_jspl » Tue Nov 23, 2010 7:53 pm
Dear All
I can't download the digsi 4.83 file please post a link for the same and obliged. (sdown)
laboul2
Post by laboul2 » Tue Oct 18, 2011 1:15 pm
hello all members
digsi 4.84 is now avaible, i have update but i don't have full dvd 4.84 (compatible with windows 7)
update:
http://siemens.siprotec.de/download_neu ... wnload.zip
request full dvd 4.84
laboul2
Post by laboul2 » Wed Oct 26, 2011 6:35 pm
DIGSI 4.85 update is available here. It can be installed over DIGSI 4.83.
http://siemens.siprotec.de/download_neu ... wnload.zip 1. 64-bit operating system support
2. Support of new Feeder Automation Controller 7SC80
3. Feeder Automation Sequence Editor (FASE)
4. Support of new Smart IED 7SJ686
5. Support of devices with multiple system interfaces
6. IEC 61850
6.1. In System Configurator, devices can be renamed without loosing configured static reports (CHDOC00032532).
6.2. Fixed sporadic problems when updating IEC 61850 station with third-party ICD (CHDOC00024520).
6.3. Consistent handling of IEC 61850 Interlocking options in DIGSI Configuration Matrix (CHDOC00032037).
7. Import and Export
7.1. Correct export of PROFIBUS DP system interface (CHDOC00032480)
7.2. Modbus system interface export works correctly (CHDOC00023976)
8. Canceled CFC changes are not transferred into device (CHDOC00030608)
9. IEC 60870-5-103
9.1. Fixed problems with 7SJ/SK devices and IEC 60870-5-103 (CHDOC00026078)
9.2. IEC 60870-5-103 address remains unchanged after download settings (CHDOC00036580)
10. Correct indication of sectionalizer (CHDOC00024675)
11. Correct feeder currents shown during bay out of service (CHDOC00024294)
12. Information about incompatible DIGSI versions is shown (CHDOC00028898)
13. User-defined symbols can be controlled in the control display (CHDOC00024032)
14. Start menu shows correct entries although DIGSI and SIMATIC are installed in parallel (CHDOC00039443)
15. All functions available after MLFB change (CHDOC00037752)
16. Show attributes of USB device (CHDOC00025017)
17. Connection with 7SJ80 works also via USB port (CHDOC00024415)
18. Display of distance zone graphic does not crash DIGSI (CHDOC00040336)
19. Improved compatibility of CFC data types (CHDOC00040585)
