[?]: full FuzzyControl ++ V5
hoangnguyen1986
Post by hoangnguyen1986 » Thu Sep 18, 2008 1:17 am
Can anyone upload the pro version of FuzzyControl++.
In demo version, i can't not to connect FuzzyControl++ with Step7.
Are there any another way???
Please help me.
Dreamer76
Post by Dreamer76 » Fri Sep 19, 2008 6:01 pm
huhu
fuzzy is already up
see board search ??
http://plc.net.ru/viewtopic.php?t=1349&highlight=fuzzy
ciao
dreamer76
hoangnguyen1986
Post by hoangnguyen1986 » Mon Sep 22, 2008 9:28 am
Thanks for your reply,but i already knew about the topic of the link that you gave me.I've download the program and install in my PC but it seem that some problem with the crack and i still see an error measage "Function is not availbe with DemoVersion" when i try to link the software to SIMATICS7.
So pls give me some solution for this situation.
Thanks very much
hoangnguyen1986
Post by hoangnguyen1986 » Thu Sep 25, 2008 3:24 pm
everybody there???
Pls help me! I still can't connect FuzzyControl with Simatic Manager.It's always have the error message "....it's not available for Demoversion" so what should i do now?
Pls help me
Dreamer76
Post by Dreamer76 » Sat Sep 27, 2008 2:52 am
huhu
i download it and it works on my pc. dont know why not on your pc....
ciao
dreamer76
Post by CoMod » Sat Sep 27, 2008 6:16 am
I have tryed these keys
but it not work with this DEMO version
guolibin
Post by guolibin » Mon Sep 29, 2008 3:23 am
Please Up to Rapidshare.
Post by CoMod » Mon Sep 29, 2008 4:23 am
guolibin wrote:Please Up to Rapidshare.
I self wait original FuzzyControl
http://plc.net.ru/viewtopic.php?t=8869
hoangnguyen1986
Post by hoangnguyen1986 » Tue Sep 30, 2008 12:12 am
so what should we do?
who know about this?Pls tell for everybody
thanks alot
we still get a trouble with the software,it seem that we miss something so it always display an error measage "Demo"
hoangnguyen1986
Post by hoangnguyen1986 » Mon Oct 27, 2008 3:13 pm
anybody help me
i still can't connect the Fuzzycontrol v5++ with my PLC
pls
Please help me !
hoangnguyen1986
Post by hoangnguyen1986 » Mon Nov 03, 2008 8:05 am
well well i tried to do anything i can but i still done nothing with the FuzzyControl software>>>>>Who can upload the software with the full lisence.Thanks very much! :(
bozob
Post by bozob » Fri Nov 07, 2008 8:34 am
Try with PLCSIM first.
Make sure you have installed PLCSIM v5.4. (older version didn't have SIM drivers separated but only MPI driver),
then go to config PC/PG and use PLCSIM(MPI) driver (S7ONLINE (STEP7) -->PLCSIM(MPI))
In Fuzzy select target (S7-4K or 20K) and connect to target.
default settings are MPI address: 2
rack: 0, slot: 2, datablock: 30 (for S7-4k) or 31 (S7-20K)
make sure you have all the blocks (FB FC and DB) already downloaded in the PLC (PLCSIM).
if you still have errors try using original Fuzzy software (not cracked dlls) and EKBs from which can be found over the internet.
hoangnguyen1986
Post by hoangnguyen1986 » Sat Nov 08, 2008 8:23 am
Thanks you very much for your advice,I will try to do something that you told me,and i will tell you about my result
Thanks agains
bozob
Post by bozob » Mon Nov 10, 2008 9:53 am
This are some further instructions which I already sent to your PM.
I my case I use PLCSIM (testing purposes), however PLCSIM can be easily changed with real PLC (S7300 or 400).
You need Step 7, PLCSIM v5.4 as I mentioned, FuzzyControl v5.0 and licenses (EKBs)
You can use original FuzzyControl instalation + licenses or cracked version from the forum.
I have installed licenses: FuzzyControl++ Base, and Fuzzy Control++ Industrial ethernet. If you have cracked version then I think you don't need licenses.
After installation of FuzzyControl you open step7 project and load libraries from fuzzy to your project. Start a new OB1 (or OB32,etc) and insert FB30 (s7-4k platform) to network, what will automatically create DB30. If you use s7-20k platform use FB31. This depends on the amount of memory you nee and the PLC has. (I use s7-4K for tests)
From the step manager click to power on PLCSIM (icon) and download the project step7 to the Simulator. You should have OB(x) block, FB3(y) and DB3(y) blocks in the PLCSIM (or PLC).
Then save plcsim copnfiguration so yuo can start it again later if you want without step7 dowloding the program AND shutdown STEP7!!!
Important as Step7 and Fuzzy cannot be connected to PLCSIM at the same time. While PLCSIM is running you start Fuzzy Control.
Go to Fuzzycontrol, create New project (in cracked version or if you have licenses you avoid message "This is a demo version .... ") . Define lets say 2 inputs, 2 outputs. In Targetsystem - Manager you should have S7-4K or S7-20K and others platforms.. then Select s7-4K platform and then Connect: new window appears.. (my settings are)
S732.dll - correct the path to the dll file. Usually it is in C:\WINDOWS\system32\s732.dll
In Connection information: select "S7online". you have set in the PC/PG settings before that S7online means: S7ONLINE STEP7 -- PLCSIM(MPI))
Connection parameters: MPI, Target adsress: 2, Rack: 0, slot: 2, DB: 30 (depnds what platforrm you selected FB30, DB30 or FB31, DB31)
press OK and connect. IT should say that DB block is empty and the connection is successful. then you download or upload fuzzy projects.
If you have still problems, post an image of the error you get here , to see if the problem is in the Fuzzy, drivers, licenses...
bye.
hoangnguyen1986
Post by hoangnguyen1986 » Mon Nov 10, 2008 3:26 pm
sorry but i don't know how to upload the image to the forum so i upload some pictures to Rapidshare pls don't concern about it.
I've sent a private message to you,pls help me
There is the link for "error picture" when i try to connect FuzzyControl
Link_is_Dead :(/P ... r.Link_is_Dead :(
bozob
Post by bozob » Mon Nov 10, 2008 10:07 pm
Ok, the first picture is normal... the second picture shows you have problems with trial version of FuzzyControl. Find Fuzzy EKBs on the Forum, somebody uploaded the EKBs recently (check topic "Simatic Neurosystems Key/software"). Then you can also use original version of FuzzyControl and not cracked version.
1. Make sure you are using License Manager version 2 or 2.2 + something... it must not be version 3 (cracked licenses will not work).
The problem is if you instal PLCSIM v5.4, it will automaticaly install License Manager version 3. Install it and install version 2.2 or 2, from Step7 software.
I also see in the picture that the Simatic manager is still running in tha taskbar on your computer. Make sure PLCSIM is running alone, so to be sure close the Step7 manager after you download blocks to the PLCSIM. Then connect to the target with FuzzyControl.
Third picture error: Check if you have PLCSIM version 5.4 installed, I think I had the same error, before I corrected settings in PC/PG. PLCSIM version 5.4 installs additional communication drivers PLCSIM(MPI). In PC/PG settings you define S7ONLINE STEP7 --> PLCSIM(MPI).
In the fourth picture you can not set parameters because you dont have licenses (DEMO version). Try to install licenses from the forum... then set evrything as I mentioned in previous post.
Let me know if you make any progress,
bye.
hoangnguyen1986
Post by hoangnguyen1986 » Tue Nov 11, 2008 2:23 pm
Thank for your instruction!
I use Automation License Manager V1.0Sp1 and i think it can be recognize the FuzzyKey, the I do everything exactly as you said. It's don't have the error like the Second picture ( i sent you ) but it still have the error like the Thirth picture ( something relate to "can't not load the S732.dll"). You said that the right path for this file is " C:\Windows\system32\s732.dll" but when the Fourth picture appear i can see that the path is not correct,The path is " C:\WindowNT\system32\s732.dll" is there something wrong??
I really need your help because i must be connect FuzzyControl with S7 for my Final exam at my University.So, can you give me your YahooID or something like that ,after that i can chat with you to find out more information ( I think it's easier for me to solve my problem)
You have my thank because what you've done for me!
Pls reply!
Thanks!
Ps: my YahooID is " you_tml200"
hoangnguyen1986
Post by hoangnguyen1986 » Mon Nov 24, 2008 12:25 am
Thanks Bozob!
Now, everything is Ok,i did it
FuzzyControl is working perfectly
