Victor Yeo
Post
by Victor Yeo » Thu Aug 28, 2008 6:25 am
when I start s7 Trainer cannot continue ( I'm use STEP7V5.4 & PLCSIM V5.4 ), to appear popup message :
s7trainner wrote:"s7trainner_app1.exe has encountered a problem and needs to close,
we are sorry for the inconvenience"
and detail report :
Error signature
AppName s7trainer_app1.exe ModName:kernel32.dll
ModVer 5.1.2600.2991 Offest 0012a5b
but I'm try other PC use PLCSIM 5.1 & STEP7 V5.1 running normal
wheter S7 Trainer only running this version ???
Post
by CoMod » Thu Aug 28, 2008 6:59 am
You can try with PLCSIM v5.3.
I also have problem with connection to ActiveX module of PLCSIM v5.4.
But me VB program work with PLCSIM v5.3.
Siemens change PLCSIM v5.4, but ActiveX DLL for connect to external program not changed - is old from previous version !
Dreamer76
Post
by Dreamer76 » Thu Sep 04, 2008 7:49 pm
huhu victor yeo
s7 trainer not work because siemens changed the libraries supplied so that s7 trainer does not work with plcsim v5.3.1 and higher.
had same problem
ciao
dreamer76
