joopiter
Post
by joopiter » Tue Jan 29, 2008 10:12 am
hello friends
I have used 2 S7-300 AO(6ES7332-5HF00-OABO) card for making them redudant,
i have two problems:
1. first one is this that when two channels are ok each one should work in half range(2-20mA)
but when one channel fail the other one should work in full range,
but this is not taking place
2. the other problem is ,when two channels are ok i have many oscillation AO in one forced value,
what should i do can any one help me?
rataman
Post
by rataman » Wed Jan 30, 2008 12:51 am
it happened to me. Have u already check partner redundancy in HWconfig? Are you using CFC?
joopiter
Post
by joopiter » Wed Jan 30, 2008 4:53 am
yes hw config is ok,and i use CFC
rataman
Post
by rataman » Thu Jan 31, 2008 3:39 am
Then you should check your process image, all ao-ch blocks should be in the same ob and use Process image 1 on all ao modules. Check your hwconfig for that and it should work fine.
