[?]: FC92 SHRB function in TIA Portal STEP 7
in Simatic Step7 V5.6 I used FC92 function block for shift bits in register.
After that I migrated that aplication in TIA Step7 (for new CPU 1500), and I got error during migration.
After that I read that CPU1500 not support MCR, MCRA, MCRD instruction ant that is reason why the problem exist.
Can someone help me and is there any another function which I can use for shift bits in register for CPU 1500?
Best regards.
FC92 SHRB SHIFT Shift bit in the shift register
from "TI-S7 Converting Blocks" library
Best regards.
Re: [?]: FC92 SHRB function in TIA Portal STEP 7
If it help for you, here is the FC92 original code:
FC92 - "SHRB" (STEP 7 V5.5 + SP3)
FUNCTION "SHRB" : VOID
TITLE = BIT SHIFT REGISTER
AUTHOR : SEA
FAMILY : SHIFT
VERSION : 2.0
VAR_INPUT
DATA : BOOL ; // source data bit
RESET : BOOL ; // resets the shift register
S_BIT : POINTER ; // points to the start bit in the shift register
N : WORD ; // length of shift register (number of bits to be shifted)
END_VAR
VAR_TEMP
BLKNO : WORD ;
SAVBIT : BOOL ;
SAVNXT : BOOL ;
TMP : BOOL ;
END_VAR
BEGIN
NETWORK
TITLE =
L #N;
L 1;
<I ;
JC DONE;
SET ;
AN #RESET;
MCR( ;
// Open DB and set ptr
L P##S_BIT;
LAR1 ; // Addr.Reg1 = Ptr to Src. Table
L W [AR1,P#0.0]; // load Block No. into accum 1
T #BLKNO; // scrblk = Block No.
OPN DB [#BLKNO]; // opens 1st Block, DB
L D [AR1,P#2.0]; // load Block Area Reference
LAR1 ; // load Block Addr.(area ref.)into Addr.Reg1
SET ; // place DATA into SAVNXT & SAVBIT
A #DATA;
= #SAVNXT;
= #SAVBIT;
L #N;
SHFT: T #N;
MCRA ;
SET ;
A [AR1,P#0.1];
= #SAVNXT; // SAVNXT = P#0.1
SET ;
A [AR1,P#0.0];
= #TMP; // TMP = P#0.0
SET ;
A #SAVBIT;
= [AR1,P#0.0]; // P#0.0 = SAVBIT
SET ;
A #TMP;
= #SAVBIT; // SAVBIT = TMP
+AR1 P#0.1; // Increment pointer to next bit
MCRD ;
L #N;
LOOP SHFT;
)MCR ;
DONE: SET ;
SAVE ;
END_FUNCTION
Thanks for answer. But, some function is not supported by used CPU (S7 1500). And this code is not useful.
Best regards,
Best regards,
In basic instructions, shift and rotate.
try SHR SHL.
Good luck
try SHR SHL.
Good luck
May be SCL code will be more useful for TIA.
The POINTER I changed to 3 INT variables (see picture).
I small checked it with original FC92 they are working identically.
SHRB on SCL V5.3 + SP6
FUNCTION FC192 : VOID
TITLE = 'BIT SHIFT REGISTER'
AUTHOR : SEA
FAMILY : SHIFT
VERSION : '2.0'
//KNOW_HOW_PROTECT
VAR_INPUT
DATA : BOOL; // source data bit
RESET : BOOL; // resets the shift register
DBNo : INT; // DB number
sIDX : INT; // start index in the shift register
sBIT : INT; // start bit in the shift register
END_VAR
VAR_TEMP
BLKNO : WORD;
SAVBIT : BOOL;
SAVNXT : BOOL;
TMP : BOOL;
STR : DINT;
END : DINT;
i : DINT;
ni : DINT;
nb : DINT;
nip : DINT;
nbp : DINT;
END_VAR
BEGIN
IF WORD_TO_DINT(N) >= 1 THEN
STR := sIDX * 8 + sBIT;
END := STR + WORD_TO_DINT(N) - 1;
BLKNO := INT_TO_WORD(DBNo);
SAVNXT := DATA;
SAVBIT := DATA;
IF NOT RESET THEN
FOR i := STR TO END BY 1 DO
ni := i DIV 8;
nb := i MOD 8;
nip := (i+1) DIV 8;
nbp := (i+1) MOD 8;
SAVNXT := WORD_TO_BLOCK_DB(BLKNO).DX[nip,nbp];
TMP := WORD_TO_BLOCK_DB(BLKNO).DX[ni,nb];
WORD_TO_BLOCK_DB(BLKNO).DX[ni,nb] := SAVBIT;
SAVBIT := TMP;
END_FOR;
ELSE
ni := i DIV 8;
nb := i MOD 8;
SAVNXT := FALSE;
TMP := FALSE;
WORD_TO_BLOCK_DB(BLKNO).DX[ni,nb] := FALSE;
SAVBIT := FALSE;
END_FOR;
END_IF;
END_IF;
END_FUNCTION
Thank you a lot! I try it and inform you, of course, confirm that code whether OK or not. I hope it will be!
Thank you again!
BR.
Thank you again!
BR.
I tried it. But there is problem using for S7 1500 plc.
WORD_TO_BLOCK_DB(#BLKNO).DX[#nip, #nbp] cannot be used. In Library list, doesnot exist. Maybe for S7300/S7 400 cpu it is possible.
I can't compile it.
BR.
I can't compile it.
BR.
- Faq & Info
try s7canopener viewtopic.php?p=168#p168 for unprotect your blocks after this try migrate
You can try to change code with PEEK and POKE instructions:
I have not TIA and can not to check it.
SAVNXT := PEEK_BOOL(area := 16#84, dbNumber := DBNo, byteOffset := nip, bitOffset := nbp);
TMP := PEEK_BOOL(area := 16#84, dbNumber := DBNo, byteOffset := ni, bitOffset := nb);
POKE_BOOL(area := 16#84, dbNumber := DBNo, byteOffset := ni, bitOffset := nb, value := SAVBIT);
and
POKE_BOOL(area := 16#84, dbNumber := DBNo, byteOffset := ni, bitOffset := nb, value := FALSE);
https://support.industry.siemens.com/cs ... 3&lc=en-AE
and
I want to confirm that suggested instruction in function SHRB work!! I made it, used in my aplication. Done.
Thank you a lot!
Best regards,
Thank you a lot!
Best regards,
