ggg315
Post
by ggg315 » Mon Jun 29, 2020 11:48 am
What is this instruction in SCL in TIA Portal
Limit is defined as a constant =7
What does this mean FOR #index := #LIMIT TO 1 BY -1 DO especially the part BY -1 DO
Limit to 1 means we start at 7,6,5,4,3,1 and move to 1, but i dont understand what this ( BY -1) mean does it tell it to reduce -1 each time
https://prnt.sc/t8fws2
(* Part 1 Sorting of data ******************************************************
Swaps adjacent pairs of values using the ”bubble sort”
method until the measured data buffer is correctly sorted. *)
REPEAT
#swap := FALSE;
IF #sortbuffer[#index -1 ] > #sortbuffer[#index] THEN
#aux := #sortbuffer[#index];
#sortbuffer[#index] := #sortbuffer[#index -1 ];
#sortbuffer[#index -1] := #aux;
#swap := TRUE;
END_IF;
END_FOR;
UNTIL NOT #swap
END_REPEAT;
(* Part 2 Calculation of results ***********************************************
Calculates square root using standard function SQRT and
square using function SQUARE. *)
FOR #index := 0 TO #LIMIT BY 1 DO
#valr := INT_TO_REAL(#sortbuffer[#index]);
#resultr := SQRT(#valr);
#calcbuffer[#index].squareroot := REAL_TO_INT(#resultr);
#calcbuffer[#index].square := "SQUARE" (#sortbuffer[#index]);
END_FOR;
Answers to FAQs
- Faq & Info
Post
by Answers to FAQs » Mon Jun 29, 2020 2:21 pm
it is mean with BY operand only
FOR #index := (start_value) TO (end_value) BY (step) DO
operand FOR not compare between start_value & end_value, and cannot know if increment or decrement the start_value
ggg315
Post
by ggg315 » Mon Jun 29, 2020 5:56 pm
Thank you so much
Where Can I read in details about instructions of SCL
Update
- Forum Community
Post
by Update » Tue Jun 30, 2020 5:11 am
2.1 Improvements in Update 2 for TIA Portal
https://support.industry.siemens.com/cs ... /109775861
29.06.2020 wrote:Update 2 for TIA Portal contains the following improvements and changes for SCL :
SCL: Derived data types in arithmetic expressions
The rules for derived data types have been standardized. It is now no longer permitted to use these data types in arithmetic expressions in SCL.
Example:
The following expression is no longer permissible in V16 Update 2:
#myInt := #myHW_IO + 5;
In such cases, use a temporary tag of the basic data type:
#myTempUInt := #myHW_IO;
#myINt := #myTempUInt + 5;
Alternatively, you can also convert the operand explicitly to the basic data type:
#myInt := UINT_TO_INT(#myHW_IO) + 5;
ggg315
Post
by ggg315 » Tue Jun 30, 2020 7:14 am
FUNCTION_BLOCK TEST
VAR_INPUT
FINALVAL: INT; //Input parameter
END_VAR
VAR_IN_OUT
IQ1: REAL; //In/Out parameter
END_VAR
VAR_OUTPUT
CONTROL: BOOL;//Output parameter
END_VAR
VAR
INDEX: INT;
END_VAR
BEGIN
CONTROL:= FALSE;
FOR INDEX:= 1 TO FINALVAL DO
IQ1:= IQ1 * 2;
IF IQ1 > 10000 THEN
CONTROL:= TRUE;
END_IF;
END_FOR;
END_FUNCTION_BLOCK
In above code the step is not there so how it will know what the step is ?
Answers to FAQs
- Faq & Info
Post
by Answers to FAQs » Tue Jun 30, 2020 4:57 pm
default parameter BY is = +1
