Hello
If we make a request with the code number 6es7660-6HQ71-1DF6, Siemens must have the card CP1623 installed by the factory or we will have to buy it again from Siemens.
New ipc 847D
Re: New ipc 847D
SIMATIC PCS 7 IND. WORKSTATION IPC847D
6ES7660-6HQ71-1DF6
Processor + Systemtype: [ H ] Xeon E3-1268L v3 (4C/8T, 2.3 GHz, 8MB Cache, TB, VT-d, AMT) - OS Server
Drives: [ Q ] RAID5, 2 TB (3 x 1 TB HDD SAS, striping with parity); removable disks, hot-swap; frontside mounted; PCIe x8 HW-RAID Controller incl. ZMCP-Modul, (2 Slot occupied) + 240 GB SSD (eMLC) SATA, removable disk; frontside mounted;
Main Memory: [ 7 ] 32 GB DDR3 SDRAM (4x 8 GB), ECC, Dual Channel
Communication: [ 1 ] Industrial Ethernet (CP1623)
PCS 7 Version: [ 1 ] PCS 7 V8.1 + SP1 pre-installed
Operating system: [ D ] Windows Server 2008 R2 Standard Edition inkl. 5 Client, 64bit, MUI (en, ge, fr, it, sp, ch)
Board / Exchangeable media /: [ F ] Board with 11 Slot: 3x PCI, 3x PCIe x4, 5x PCIe x16; DVD±RW (Slim) + Multi Monitor 4 Screens PCIe x16 Card
Power supply, Country specific PS cord: [ 6 ] 2 x 110/230V Redundant-PS; without power cord
6ES7660-6HQ71-1DF6
Re: New ipc 847D
So should this card be installed when this computer is purchased?
Re: New ipc 847D
It will be installed by the manufacturer, neither need to buy nor to install it by yourself.
Re: New ipc 847D
I buy this ipc but no has this device
Re: New ipc 847D
We have 7 such IPCs (4 OS servers + 3 ES). CP1623 has been installed everywhere by default.
Check again the order number for the Communication digit on the case sticker. If it is exactly "1" and there are no CP1623 - it's a cause for complaint against the seller.
