[?]: how this SCL block works
ggg315
Post by ggg315 » Sat Sep 07, 2019 5:06 pm
Could someone explain me how it works ?
https://docdro.id/e7ZCprT
Re: I need help To understand how this block works
Post by CoMod » Sat Sep 07, 2019 8:35 pm
и что конкретно в этой простыне не понятно ?
Comments in Russian understand ?
ggg315
Re: [?]: how this SCL block works
Post by ggg315 » Mon Sep 09, 2019 6:52 am
No. I need help with SCL code .
Post by CoMod » Mon Sep 09, 2019 7:35 am
add :?: in PDF (rr)
pigroplc
Post by pigroplc » Mon Sep 09, 2019 8:30 am
ggg315,
you better deeply study the interface with the motor considered by the code, then later on, you will understand the code.
The code itself has just some IF...THEN and it's quite easy to understand how it works.
Post by CoMod » Mon Sep 09, 2019 1:44 pm
your native language ?
In this block comment in Russian - you know Russian ?
Do you know Siemens programming languages LAD/STL/FBD/SCL ?
