Hi here,
I'm looking for a S7 driver can be use in C++.
There is the fantastic Snap7 but it need to activate Get and Put. Whatever, i'm not sure about password communication.
does simatic .net can be use with external app ?
there is a api to comunicate with S7-1200 / S7-1500 without Get/Put option and with read password ?
Simatic net for C++
Re: Simatic net for C++
Rogue Engineering-Station attacks on S7Simatic PLCs
https://i.blackhat.com/USA-19/Thursday/ ... LCs-wp.pdf
https://i.blackhat.com/USA-19/Thursday/us-19-Bitan-Rogue7-Rogue-Engineering-Station-Attacks-On-S7-Simatic-PLCs-wp.pdf
interresting pdf,
i only need to read/write plc value and use a friendly tool to do that. (don't ready to make my own S7 com)
if we have a S7-1500 plc, siemens give only wincc adv/pro to control the process ? can we use simatic .net to do my own tool ?
Edit: isn't for a pro dev. it more for personnal use
https://www.mhj-tools.com/comdrvs7/ for S7-300/400/1200/1500/Logo
Put/Get setting (see 7:28)
and know Password and notsymbolic addressable DB* is required always
*Read and write data blocks (addresses). This is only possible if the data block not created with the option "only via symbolic addressable"
only unlock pcu / get-put activated / not optimised data can communicate :/
I am surprised that there is no solution to make are own HMI.
i can't use simatic net do to it?
