HI ALL ,
installing pcs7 7.1 sql database service error while installing
LOG FILE :
Product Installation Status
Product : Setup Support Files
Product Version (Previous): 1546
Product Version (Final) :
Status : Failure
Log File : C:\Program Files\Microsoft SQL Server\90\Setup Bootstrap\LOG\Hotfix\Redist9_Hotfix_KB955706_SqlSupport.msi.log
Error Number : 1260
Error Description : MSP Error: 1260 Windows cannot open this program because it has been prevented by a software restriction policy. For more information, open Event Viewer or contact your system administrator.
Event Viewer :
NET Runtime Optimization Service (clr_optimization_v2.0.50727_32) - Failed to compile: PresentationUI, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 . Error code = 0x80070002
The description for Event ID ( 11260 ) in Source ( MsiInstaller ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. You may be able to use the /AUXSOURCE= flag to retrieve this description; see Help and Support for details. The following information is part of the event: Product: Microsoft SQL Server Setup Support Files (English) -- Error 1260. Windows cannot open this program because it has been prevented by a software restriction policy. For more information, open Event Viewer or contact your system administrator.
, (NULL), (NULL), (NULL), (NULL), , .
