[LINK]: STEP 7 V5.6 SR2 Professional version 2017/2020
xflash
Post by xflash » Fri Jun 02, 2017 6:32 am
STEP 7 V5.6 SP2 / STEP 7 Professional 2017 SR2
https://support.industry.siemens.com/cs ... /109773842
Hotfix 1 STEP 7 V5.6 SP2 / STEP 7 Professional 2017 SR2
https://support.industry.siemens.com/cs ... /109775201
Download Hotfix 2 STEP 7 V5.6 SP2 / STEP 7 Professional 2017 SR2
https://support.industry.siemens.com/cs ... /109778416
2020/05
Download Hotfix 3 STEP 7 V5.6 SP2 / STEP 7 Professional 2017 SR2
https://support.industry.siemens.com/cs ... /109779992
HW Config
• Adding connections via command interface has been improved.
• As of this Hotfix: The configuration of Safety modules via GSD has been improved.
• As of this Hotfix: It is now once again possible to configure I devices in shared mode.
Programming LAD/STL/FBD blocks
• The function "Check and Update Accesses" has been improved.
https://support.industry.siemens.com/cs ... /109747981
STEP 7 V5.6 Upd4 Registrierung notwendig Download (EU) (463,0 MB)
https://support.industry.siemens.com/cs ... re-updates
https://support.industry.siemens.com/cs ... HF4_EU.zip
STEP 7 V5.6 Upd3 Registrierung notwendig Download (EU) (439,0 MB)
STEP7 Professional 2017 with STEP 7 V5.6 HF1
(sdoc) https://support.industry.siemens.com/cs ... ry-release
(sdown) https://support.industry.siemens.com/cs ... al-license
HF2 for STEP 7 V5.6
https://support.industry.siemens.com/cs ... ts-updates
It has S7-BlockPrivacy inside and FM Configuration Package (like fm-x50), CP PtP-Param in Optional Components, but no s7-scl and modbus. (boom)
So we are just waiting for Professional version (with s7-scl, s7-graph, s7-plcsim).
If some good guy know the information, please share. Thank you. (thnx)
About keys and Sim_EKB_Install - Здесь говорить о ключах
viewtopic.php?f=30&t=218
нужен экран АЛМ с установленными ключами
возможно ты попал на коллизию с ключом на Проф 5.6 - надо ставить Проф ключ для Портала 14.1 или 15.0
STEP7 v5.6 Basis license: WORKS
STEP7 v5.6 Professional license: DOES NOT WORK
STEP7 v14 Professional Combo license: DOES NOT WORK
(h)
yes... valid key for STEP7 v14.1 Professional (thnx) / для STEP7 PROFESSIONAL 2017 подходит ключ от v14.1
see New keys folder / смотрите ключ в папке Новые ключи
[/quote]
в последующих ЕКБ коллизия поправлена
Update W10 to v1703 https://www.microsoft.com/en-us/accessi ... s10upgrade
Step7 show MSVCR100.DLL error message (boom)
Install Microsoft Visual C++ Redistributable for Visual Studio 2017
https://support.microsoft.com/en-us/hel ... -downloads
Обновил W10 до v1703 https://www.microsoft.com/ru-ru/accessi ... s10upgrade
Step7 показывает ошибку отсутствия MSVCR100.DLL (boom)
Установил Распространяемый пакет Visual C++ для Visual Studio 2017
https://support.microsoft.com/ru-ru/hel ... -downloads
mustaw
Re: STEP 7 V5.6 is out, waiting for Professional version
Post by mustaw » Fri Jun 02, 2017 12:59 pm
Thanks for the info.
Seems there is a lot which doesn't work anymore in v5.6 with Win10.
Not working with Step7 v. 5.6 + Win10:
CFC
D7-SYS
DOCPRO
MODULAR PID CONTROL TOOL
PID SELF-TUNER FBs
S7-Distributed Safety
S7-F Systems
S7-PDIAG
S7-Technology
SIMATIC iMap
SIMATIC Logon
SIMATIC Maintenance Station
SIMATIC NET SOFTWARE PACKAGE
SIMATIC Safety Matrix
SIMOTION SCOUT
SINAUT Engineering
Standard PID Control Tool
Not sure how much of the above will be needed in the future.
Looks like WinCC works with Win10 though, except WinCC flexible 2008+ if my understanding is correct.
Full list here: https://support.industry.siemens.com/cs ... y_list.pdf
but wait PCS7 v9.0 (suc)
https://www.siemens.com/global/en/home/ ... -7/v9.html
Link
Re: [LINK]: STEP 7 V5.6 Torrent
Post by Link » Sat Jun 03, 2017 8:46 am
Torrent
https://rutracker.org/forum/viewtopic.php?t=5411400
dirrect link for torrent client
Step7_v5.6_ISO_upd_rutracker.org.t5411400.zip
*********** wait SP1 ****************
very slow on Windows 10 (h) and with (boom)
van8x10
Re: [LINK]: STEP 7 V5.6 is out, waiting for Professional ver
Post by van8x10 » Fri Jun 09, 2017 1:26 am
STEP 7 V5.6 runs very slowly on Windows 10 Pro 64bit (h) ! (version 1703, Build 15063.332)
Update
Post by Update » Fri Jun 09, 2017 10:07 am
Torrent Updated = add S7-SCL v5.6 + S7-GRAPH v5.6 + PLCSIM v5.4 SP8
Please redownload to same folder
Раздача обновлена - добавлены S7-SCL v5.6 + S7-GRAPH v5.6 + PLCSIM v5.4 SP8
перекачайте в ту же папку
direct link for torrent client https://mega.nz/#F!Ww9SCCZQ!6NhIu768fib7w2DUFu0wPw
CNJBH
Post by CNJBH » Sun Jun 18, 2017 3:05 am
Anyway your are guy always make perfect professional works! Thanks! (gpost)
Post by CoMod » Tue Jul 25, 2017 6:13 pm
pisoj wrote:Simulations wont work for me.
Windows 10 x64 work
Post by CoMod » Tue Jul 25, 2017 6:16 pm
xflash
Post by xflash » Thu Aug 10, 2017 1:16 am
Only things we can do is to wait. There is a long way that step7 5.6 could be used on site.
xf2000
Post by xf2000 » Fri Aug 11, 2017 10:41 am
STEP7 Professional 2017 with Hotfix 1 for STEP 7 V5.6
What has Changed hotfix 1 for STEP 7 V5.6 Compared to Version STEP 7 V5.6?
Installation of hotfix 1 for STEP 7 V5.6
As of this hotfix: If after installing a hotfix 1 for STEP 7 V5.6 the original installation is changed with "Change program" or "Repair program" the hotfix needs to be installed again.
HW Config
Ab diesem Hotfix: In a configuration that uses the function "Use different method to obtain IP address" there is no longer a warning relating to the NTP server address and another subnet.
SIMATIC Manager
As of this hotfix: The display of the object size of objects larger than 2 GB has been improved.
Report System Errors
As of this hotfix: A battery fault is also displayed for a CPU if this is operated in a non-redundant configuration.
Link
Re: [LINK]: STEP 7 V5.6 Professional version 2017
Post by Link » Fri Aug 11, 2017 11:37 am
torrent update
SIEMENS_SIMATIC_STEP7_v5.6_Professional_2017_rutracker_torrent.zip
van8x10
Post by van8x10 » Sat Aug 12, 2017 7:36 am
STEP 7 2017 Pro (V5.6) runs very slowly on Windows 10 Pro 64bit (h) ! (version 1703, Build 15063.332)
Re: [LINK]: STEP 7 V5.6 HF1 Professional version 2017
Post by CoMod » Sun Aug 13, 2017 9:05 pm
maybe I am the first, who informs you that the following licenses does not work with the
newly available STEP7 PROFESSIONAL 2017 installation media which installs Step7 v5.6 HF1.
Download the new installation ISO:
https://support.industry.siemens.com/cs ... 109749428/
(h)
KPPNST
Post by KPPNST » Thu Aug 31, 2017 8:56 am
van8x10 wrote:STEP 7 2017 Pro (V5.6) runs very slowly on Windows 10 Pro 64bit (h) ! (version 1703, Build 15063.332)
It runs and works on Windows 10 Enterprise RUS v1703 x64 (15063.540) (i7-4710HQ + 8Gb RAM + SSD 256G) very well and fast.
van8x10
Post by van8x10 » Mon Sep 11, 2017 2:54 am
Yeah, I've reset my laptop and re-installed the software, and now it works well!
MILSANT2016
Post by MILSANT2016 » Sat Nov 25, 2017 9:16 pm
friends
Download the software from Step 7 v 5.6 indicated on the page.
When I want to install everything, it is going well until you inform me that Step 7 v5.6 can not be installed because the computer has installed step 7 V5.6 HF1 WHAT IS NOT TRUE WHAT HAPPENS AND PLEASE IF SOMEONE CAN HELP ME
THANK YOU. (oo) (h)
MILSANT2016
Post by MILSANT2016 » Sun Dec 03, 2017 11:09 pm
Dear
A while ago I had a problem with the EKB ESPECIALLY THOSE OF 2017 _8.
I DO ALL THE OPERATIONS THROW THEM IN THE FOLDER
AX NF ZZ BUT DO NOT TAKE THE PROGRAMS.
MY OPERATIVE SYSTEM IS WINDOWS 10 PRO OF 64 BITS.
I INSTALL ANY SIEMENS PROGRAM AND DO NOT ACTIVATE IT WHAT CAN IT BE? NEITHER DOES THE AUTOMATION MANAGER CONNECT THE EKB PROGRAM WHAT CAN I DO? THANK MUCH.
roberto_battistella
Post by roberto_battistella » Sat Jan 06, 2018 9:29 pm
you can download hf3 only after opening a ticket to the support request (or I can pass it through we transfer)
xflash
Post by xflash » Sun Jan 21, 2018 7:52 am
roberto_battistella wrote:you can download hf3 only after opening a ticket to the support request (or I can pass it through we transfer)
Please do that or upload to mega. Thank you a lot.
xflash
Post by xflash » Thu Feb 08, 2018 10:10 pm
ilmisu wrote:any feedback to install distributed safety onto step 7 5.6?
It works on me, but I did not use it in real system yet.
Update
Post by Update » Mon Feb 12, 2018 6:31 pm
rekram
Re: [LINK]: STEP 7 V5.6 HF2 Professional version 2017
Post by rekram » Thu Feb 15, 2018 10:15 am
Hi, can you write what are new features in this version, something something besides compatibility with Windows 10?
Update
Re: [LINK]: STEP 7 V5.6 HF3 Professional version 2017
Post by Update » Sun Apr 29, 2018 9:21 pm
boldive
Re: [LINK]: STEP 7 V5.6 HF4 Professional version 2017
Post by boldive » Sat May 19, 2018 4:41 pm
Have installed HF4. There is NO performance changes. v.5.6 is very slow. Most of the time I am using v.5.5
xflash
Post by xflash » Thu May 31, 2018 9:12 am
boldive wrote:Have installed HF4. There is NO performance changes. v.5.6 is very slow. Most of the time I am using v.5.5
Are you using Windows 10 or Win7 ?
Post by Dfcz » Thu May 31, 2018 9:37 am
Laptop core i5 memory 6 GB normal hard - Step7v5.6HF4 and winCCflexible2008HF5 work - fly.
MEFinc
Post by MEFinc » Mon Jul 30, 2018 9:01 pm
Hotfix 5 download for STEP 7 V5.6 and STEP 7 Professional 2017
(sdown) https://support.industry.siemens.com/cs ... ional-2017
boldive
Post by boldive » Mon Sep 10, 2018 1:38 pm
xflash wrote: Are you using Windows 10 or Win7 ?
Win7 Enterprise on VMWare.
Same virtual machine works mach faster with v.5.5
So, this is not an operating system, this is the v5.6 itself.
xflash
Post by xflash » Tue Sep 25, 2018 2:18 am
Try step 7 5.6 hf5.
Link
Re: [LINK]: STEP 7 V5.6 SR1 Professional version 2017/2018
Post by Link » Sat Oct 27, 2018 9:30 am
Update
Post by Update » Wed Nov 14, 2018 8:43 pm
Sim_EKB_Install Folder
Torrent https://rutracker.org/forum/viewtopic.php?t=5572061
Sim_EKB_Install_2018_11_14 for WinCC v7.5
https://mega.nz/#!3CR0jCZZ!1qAYwkecwNAw ... JlRbA_FdGs
Umencho
Post by Umencho » Sun Mar 10, 2019 1:53 pm
ilmisu wrote:
Mon Feb 05, 2018 1:13 pm
Go with Update 2 for SIMATIC S7 Distributed Safety V5.4 SP5, especially if WIN10 is the OS.
https://support.industry.siemens.com/cs ... y-v5-4-sp5
As a registered customer, you can download Update 2 for SIMATIC S7 Distributed Safety SP5.
Update 2 is for
upgrading SIMATIC S7 Distributed Safety V5.4 SP5
New installation = Full version
Use as 14-day trial version for test purposes or Sim_EKB
MEFinc
Post by MEFinc » Thu May 09, 2019 2:48 pm
(sdown) Hotfix 3 STEP 7 V5.6 SP1 / STEP 7 Professional 2017 SR1
What has Changed Compared to Version STEP 7 V5.6 SP1? wrote: HW Config
· The installation of HSPs is now possible using the command line call via the HSP installer. You can find more information in the help on configuring the hardware in topic "Installing HW Updated via the Command Line".
· The operation of a DP/FF-Link downstream from an IE/PB-Link V3.1 is now possible.
· As of this Hotfix: A configuration in RUN is now once again possible for specific configurations that were downloaded to the CPU with STEP 7 V5.5 SP4 HF9.
NetPro
· The output of warnings during compilation in NetPro has been improved.
Report System Error
· Generating 'Report System Error' has been improved.
xflash
Post by xflash » Fri May 17, 2019 3:17 am
It says:
This entry is currently under revision.
so, we need waiting.
Umencho
Post by Umencho » Wed Aug 21, 2019 7:55 pm
Togomi
Post by Togomi » Wed Aug 28, 2019 8:34 pm
I have to install Step 7 on W10 and I've found Step 7 v5.6 SP1 and Step 7 Professional 2017 SR1.
I checked that Professional includes PLCSIM, S7-GRAPH...
Which one should I install?
v5.6 SP1 requires to install PLCSIM and S7-GRAPH after, doesn't it?
And I've found HF3 and HF5.
Sould I install both or HF5 is enough?
Should I install with v5.6 SP1 and Professional 2017 SR1? Do both require the update?
The most recent EKB I have is from November 2018. Is there another one more recent?
Post by CoMod » Thu Aug 29, 2019 4:50 am
"STEP 7 Professional" is TradeMark of install package = STEP 7 V5.* + PLCSIM + S7-SCL + S7-Graph
Hotfix N+1 include Hotfix N = see size
https://new.siemens.com/global/en/produ ... er-sw.html
Togomi
Post by Togomi » Thu Aug 29, 2019 9:27 am
Do you know if HF3 or HF5 are important?
https://support.industry.siemens.com/cs ... /109767446
I had v5.6 in W10 two years ago and Step 7 had problems that required HF's to solve them.
I don't know how Step 7 v5.6 SP1 works on W10 recently.
Greets
Umencho
Post by Umencho » Thu Aug 29, 2019 4:18 pm
Step 7 5.6 SP1 is working on WIN10.
Check the projects on which you will work and based on that select the software they will need.
h4rdw4re
Re: [LINK]: STEP 7 V5.6 SR1 HF5 Professional version 2017/2018
Post by h4rdw4re » Sat Aug 31, 2019 8:18 am
(sdown) Download Hotfix 5 STEP 7 V5.6 SP1 / STEP 7 Professional 2017 SR1
https://support.industry.siemens.com/cs ... 0&lc=en-US
Togomi
Post by Togomi » Wed Sep 04, 2019 3:23 pm
Step 7 Professional 2017 working on W10.
Howi
Post by Howi » Thu Sep 19, 2019 9:48 am
hi (welc)
do we have pdiag 5.6 key?
(pgood)
Post by CoMod » Thu Sep 19, 2019 2:50 pm
Update
[LINK]: STEP 7 V5.6 SR2 HF1 Professional 2017/2020
Post by Update » Wed Jan 08, 2020 6:26 pm
  • What has Changed Compared to Version STEP 7 V5.6 SP2?
    HW Config
    • As of this Hotfix: Adding connections via command interface has been improved.
    • As of this Hotfix: The function "Check and Update Accesses" has been improved.
shadow06
Re: [LINK]: STEP 7 V5.6 SR2 Professional version 2017/2018
Post by shadow06 » Tue Jan 28, 2020 6:15 am
mega or torrent link please (dlink)
misa1515
Post by misa1515 » Mon Mar 02, 2020 4:13 pm
