[INFO]: Simatic RoadMap - Step7 v5.6, TIA v15, PCS7 v9.0
Info
Re: [INFO]: Simatic RoadMap - whats new in Step7, PCS7..
Post by Info » Wed Nov 30, 2011 5:02 pm
SIMATIC Controllers
The innovative solution for all automation tasks
Overview • November 2011
https://www.automation.siemens.com/sale ... iew_en.pdf
SIMATIC Controllers
Brochure · November 2011
https://www.automation.siemens.com/sale ... ler_en.pdf
Info
Re: [INFO]: Simatic RoadMap - whats new in Step7 v11, PCS7..
Post by Info » Thu Dec 01, 2011 6:30 pm
SPS/IPC/DRIVES 2011 closed -
https://www.industry.siemens.com/topics ... fault.aspx
Wait STEP 7 V11 SP2
http://support.automation.siemens.com/W ... n/38693794
Update V2.2.0
Key features supported by S7-1200 CPU firmware V2.2.0 include:
SCL (Structured Control Language)
Download in RUN
New modules are available:
CM 1243-2 AS-i Master
CM 1241 RS422/485
SM 1222 DQ8 RLY Changeover
Required software: STEP 7 V11 SP2 Basic or Professional.
Note
Communication errors might occur on very fast computers between STEP 7 V11 SP2 and S7‑1200 CPUs versions 1.x through 2.1 Upgrade the CPU firmware to V2.2 to correct these issues
Info
Post by Info » Mon Dec 05, 2011 8:05 pm
http://support.automation.siemens.com/W ... n/55052588
SIMATIC WINCC BASIC V11 SP2 ENGINEERING-SW
6 LANGUAGES(GE,EN,IT,FR,SP,CH),
EXECUTABLE UNDER WINDOWS XP (32 BIT) / WINDOWS 7 (32/64 BIT)
FOR CONFIGURATION OF SIMATIC BASIC PANELS
Update
Post by Update » Fri Dec 16, 2011 2:43 pm
New Demo projects for HMI Panels at WinCC (TIA Portal) for Basic Panels, Comfort Panels and WinCC Runtime Advanced (TIA Portal)
http://support.automation.siemens.com/W ... n/50599077
Info
Post by Info » Fri Dec 16, 2011 5:13 pm
Update 1 for the SIMATIC PCS 7 V8.0 !?
http://support.automation.siemens.com/D ... n/56974404
The Update 1 for the SIMATIC PCS 7 Basis Library V8.0 referenced for downloading below it is only of relevance for SIMATIC PCS 7 V8.0 and must be installed on the Engineering Station of the process control system.
About SIMATIC PCS 7 V8.0 (01/2012) and WinCC V7.0 SP3 (01/2012)
http://support.automation.siemens.com/D ... e/57251375
Windows XP Embedded Standard 2009
● Windows XP Professional SP3 (32Bit)
● Windows Server 2003 SP2 Standard Edition (32Bit)
● Windows Server 2003 R2 SP2 Standard Edition (32Bit)
● Windows 7 Ultimate SP1 (32Bit)
● Windows 7 Ultimate SP1 (64 Bit)
● Windows Server 2008 SP2 Standard Edition (3 2Bit)
● Windows Server 2008 R2 SP1 Standard Edition (64 Bit)
STEP 7 Basis V5.5 + SP2
WinCC V7.0 SP3
WinCC V7.0 SP3 http://support.automation.siemens.com/W ... n/55987264
Service Pack 1 for S7 F Systems V6.1 http://support.automation.siemens.com/W ... e/57352606
Service Pack 1 for SIMATIC Safety Matrix V6.2 http://support.automation.siemens.com/W ... e/57354050
Support Windows 7 Ultimate (32/64 Bit) and Windows Server 2008 R2 Standard (64 Bit)
Umencho
Post by Umencho » Sat Dec 17, 2011 8:33 pm
SP1 of PCS7 8.0 is planned for the end of summer 2012.
Selective Download
A CFC Chart will be identified as object and all changes within the chart are considered to be local
Individual charts and corresponding modification can be compiled and downloaded selectively
Significant time savings for downloading changes in a concurrent engineering scenario
Info
Post by Info » Sat Dec 31, 2011 11:22 pm
(sfaq) PCS7 v8.0 Update Licenses concept
[dead] PCS7_Update_Licenses_concept_en.pdf
PCS7 Roadmap
[dead] ID03PCS7Roadmap20110414.pdf
Factory Automation Roadmap
[dead] ID01FactoryAutomationRoadmapSessioin.pdf
BlackFlag
Request: PCS7 v8.0
Post by BlackFlag » Thu Jan 12, 2012 9:30 pm
Hi there,
Finally it's there !!
http://support.automation.siemens.com/W ... n/57251375
If somebody can upload and contribute. (sbutton)
Re: Request: PCS7 v8.0
Post by CoMod » Thu Jan 12, 2012 10:15 pm
Delivery Paper Release <> Exist in reality.
Need wait WinCC v7.0 SP3, and only after this wait PCS7 v8.0 (01/2012 !).
Umencho
Post by Umencho » Sun Jan 22, 2012 6:12 pm
product Manager wrote:The release of SP3 for WinCC flexible 2008 is carried out to date.
In stock next week WinCC flexible 2008 SP3 to be available.
Thus Window7 64 is then released.
Produktverantwortliche wrote:Die Freigabe für WinCC flexible 2008 SP3 wird aktuell durchgeführt.
Vorraussichtlich nächste Woche wird WinCC flexible 2008 SP3 verfügbar sein.
Damit ist Window7 64Bit dann freigegeben.
Post by CoMod » Sat Feb 18, 2012 7:53 pm
DiVan wrote:SP3 for WinCC flexible 2008 and SP2 for Step7 v5.5 is ready in paper only :(
SP3 for WinCC flexible 2008 released twice: 2nd release 2012-02-07 :? (1st Jan 25 2012) :)
viewtopic.php?f=4&t=17428
wait real release
Some customers with SUS software contract have the WinCC flexible 2008 SP3, wait some days
No info about Step7 v5.5 SP2
Некоторые уже получили WinCC flexible 2008 SP3
ждёмс
о доступности Step7 v5.5 SP2 нет информации
wait real release
You can see new S7-1500 on Hannovermesse 2012 (April 23rd to 27th)
Новые S7-1500 будут представлены на Hannovermesse 2012
greg2008
Post by greg2008 » Wed Feb 22, 2012 6:39 pm
S7-1500 go to 12/2012 :(
По последним слухам 1500 решили в ганновере не представлять, оттянув сие мероприятие на Нюрнберг.
Post by CoMod » Thu Feb 23, 2012 10:54 am
all keys will be 9999 ?
Russian wrote:все ключи будут 9999?
Сименс полностью ломает чёткую картину нумерации.
Ключи 9999 приходят на смену традиционным ключам к номерным версиям
Link
Post by Link » Mon Feb 27, 2012 5:51 pm
SIMATIC STEP 7 v5.5 SP2
viewtopic.php?f=30&p=52844#p52844
torrent + rapidshare
Info
Post by Info » Thu Sep 27, 2012 6:11 pm
End of production of Flexible panels OP, MP, TP, TD
Ankündigung Produktauslauf SIMATIC OP 73, OP77A, OP 77B, TP 177A, TP/OP 177B, TP/OP 277, MP 177, MP 277, MP 377, TD200, TD400
WinAC MP 2008, Push Button Panels PP7, PP17
http://support.automation.siemens.com/W ... e/62977695
http://support.automation.siemens.com/D ... e/63378583
http://support.automation.siemens.com/D ... e/63367992
http://support.automation.siemens.com/D ... e/62977435
Info
SIMATIC S7-1500
Post by Info » Tue Nov 27, 2012 10:54 am
SIMATIC S7-1500 :!: :!: :!: :!:
http://www.industry.siemens.com/topics/ ... %20S7-1500
Discover the ultimate boost in productivity and efficiency
Standard CPUs S7-1511-1PN, S7-1513-1PN, S7-1516-3PN/DP
Price              600€          1340€       3330€
Performance         1x,          1.5x,           6x
Bit operation Speed 0.06 μs,    0.04 μs,     0.01 μs
Program memory     150 KB,      300 KB ,     1 MB
DB memory           1 MB,          1.5 MB,       5 MB
Bit memories                      16 KB
I/O address area, max.           32/32 KB
Digital channels                  262 144
Analog channels                 16 384
Controllers play a key role in the automation of machines and systems – and at the same time, they must meet steadily increasing requirements.
The new SIMATIC S7-1500 controller is setting new productivity standards in terms of maximum performance and user-friendliness through its numerous innovations.
It is integrated seamlessly into the Totally Integrated Automation Portal (TIA Portal) v12 for optimal engineering efficiency.
Its outstanding system performance ensures the shortest response times and highest control quality.
In conjunction with PROFINET as the standard interface, the SIMATIC S7-1500 is becoming the new reference for performance.
Extremely short system response times boost productivity and help provide you with the utmost flexibility, reduce your time-to-market, and ensure you a quick ROI (return on investment).
Technology Integrated enables perfect drive integration via motion-control functions and PROFIdrive.
And you also benefit from maximum investment protection thanks to Security Integrated.
The SIMATIC S7-1500 is designed for optimal usability.
Thanks to numerous innovations in every detail, the controller can be quickly and easily mounted, connected, and started up.
The innovative design and easy handling also pay off during operation.
Integrated system diagnostics – generated automatically and displayed uniformly – create complete transparency with respect to system status. Its seamless integration into the TIA Portal decreases project costs because engineering and project planning are easier and more efficient than ever before – as are the new functions.
In addition, the SIMATIC S7-1500 features a comprehensive, end-to-end operating concept that enables uniform, consistent data storage.
More info about
S7-1500
http://www.automation.siemens.com/mcms/ ... fault.aspx
http://www.automation.siemens.com/mcms/ ... cpu_en.pdf
Tia Portal v12
http://www.industry.siemens.com/topics/ ... fault.aspx
Sales and delivery release for Tia Portal v12 and S7-1500 is 01/2013
WinCC v7.2
http://www.automation.siemens.com/mcms/ ... -v7-2.aspx
Umencho
Post by Umencho » Sat Dec 08, 2012 4:24 pm
Umencho
Post by Umencho » Mon Dec 31, 2012 8:28 pm
The link is deleted!
Info
Post by Info » Wed Jan 02, 2013 5:53 pm
Info
Post by Info » Fri Nov 29, 2013 4:15 am
Hannover Messe 2016
Germany, Hanover, April 25 – 29, 2016
http://www.siemens.com/global/en/home/c ... messe.html
Post by CoMod » Fri Apr 08, 2016 6:20 pm
SIMATIC PCS 7 V8.2 runs on the following operating systems:
Windows 7 Professional SP1, 64-bit (English version only)
Windows 7 Ultimate/Enterprise SP1, 32-bit and 64-bit
Windows Server 2008 R2 SP1 Standard Edition, 64-bit
Windows Server 2012 R2 Standard Edition, 64-bit
Windows 10 Enterprise 2015 LTSB, 64-bit only for Client (h) not for Step7
Step7 V5.5 + SP4 + Upd9
WinCC V7.4
Post by CoMod » Thu Apr 14, 2016 8:40 pm
xflash
STEP 7 V5.6 will come. But when?
Post by xflash » Sat Apr 22, 2017 1:06 pm
https://support.industry.siemens.com/cs ... /109746722
says:
Compatibility with other products
STEP 7 V5.4 SP4 or higher is required.
STEP 7 V5.6 or higher for Windows 10
Does anyone know any information and when will it will be released ?
Thank you.
Post by CoMod » Sat Apr 22, 2017 7:02 pm
and WinCC Flexible 2017 for Comfort Panels ? (oo)
Post by CoMod » Mon Apr 24, 2017 10:01 am
Hannover Messe 2017, April 24 – 28, 2017
https://www.siemens.com/global/en/home/ ... tions.html
презентация в youtube
youtube presentation
https://www.youtube.com/playlist?list=P ... nBDc1D2yeJ
https://www.siemens.com/global/en/home/ ... -7/v9.html
SIMATIC PCS 7 V9.0 - possible with new Step 7 v5.6 2017
[flash=400,300]https://www.youtube.com/v/IbyJ3mMn3Mk[/flash]
Re: [INFO]: Simatic RoadMap - whats new in TIA Portal V15
Post by CoMod » Fri Dec 15, 2017 7:51 am
TIA Portal V15
Simply safe – twice the efficiency! Safety Integrated for drives in TIA Portal V15
https://www.youtube.com/results?search_ ... Portal+V15
