Hello all,
Assume that i have my backup for a S7-300 series cpu in S7 V5.5 and on the other side there is a S7-1500 CPU. Is it still possible to communicate my cpu with the new plc without migrating my V5.5?
If so in Netpro how can i show it? (Just simple as inserting an other station and trying to connect by using S7-Comm blocks?)
or are there any updates (which i failed to locate till now) to show in Netpro as well...
Thanks in advance....
S7-1500 CPU Communication in S7 V5.5 Project
Re: S7-1500 CPU Communication in S7 V5.5 Project
You have to use CM 1542-5
thanks.. i will give it a try...krank wrote:You have to use CM 1542-5
