Communication between PLC S7 414 and PLC S7 417
How send DB from S7 400 to other S7 400 ? NetWork - EtherNet.
Re: Communication between PLC S7 414 and PLC S7 417
You should use following manual
https://support.automation.siemens.com/ ... d=80635207
Go to JUMP DISTRIBUTOR on page 73. Your case is described in 21.5.3 (page 101).
regards
regards
Thank you very much!
