hi experts,
correct me if im wrong which is i am about 50% sure.
the difference between the compile and download of the v7.1 and v8.0 are in 7.1 when you do compile and download changes only, it will compile all the charts even though you did not make any changes in them so it takes a time.
while in v8.0 if you do a compile and download it will only compile the chart where you make changes.
am i right? or can you explain further to me.
thanks in advance
if this is not for this post, kindly inform me so i can moved this to the correct part of the forum.
