[?]: temporisation with step7
abdou999
Post by abdou999 » Wed May 30, 2012 8:42 pm
good evening
I have a problem running a timer I want to start a "stopwatch" to evaluate the running time of a pump (how to initialize a timer to zero and not limit it?
thank you in advance
SHKODRAN
Re: [?]: temporisation with step7
Post by SHKODRAN » Sat Jun 02, 2012 6:53 pm
What do you want to measure?
The total time duration of the pump?
or time of a start / stop?
Here you have a simple example...
Call this code on OB10 every 1 minute.
A  PM06.RUN
JCN   Y250
L     PM06RTm      //Minute data type Dint
L     1
+D
T     PM06RTm     //Minute data type Dint
L     60
/D
T     PM06RTh       //Hours data type Dint
Y250: Nop 0
abdou999
Post by abdou999 » Sun Jun 03, 2012 12:22 am
i want to mesure the total time duration of the pump
dsekulic
Post by dsekulic » Sun Jun 03, 2012 9:48 am
Maybe You should look for SFC101 (Handling Runtime Meters), alongside with SFC2 (SET_RTM), SFC3 (CTRL_RTM) and SFC4 (READ_RTM).
Description of this functions You will find in System Software for S7-300/400
System and Standard Functions
SHKODRAN
Post by SHKODRAN » Sun Jun 03, 2012 6:55 pm
abdou999 wrote:i want to mesure the total time duration of the pump
So, if you do not work for "NASA" that do not need a high precision,
the code I wrote above is just fine!
Just create a DB to save partial and totals data.
Good luck.
abdou999
Post by abdou999 » Mon Jun 04, 2012 8:36 pm
thank you for all
