[?]: When Set PG/PC interface for Windows 64bit
Dear All,
Does anybody help me?
I install successfully but I can not connect to PLC because set PG/PC interface for Windows 64bit is not suitable.
Hic hic,
Please help me.
Hic hic,
Please help me.
Re: [?]: When Set PG/PC interface for Windows 64bit
Set PG / PC Interface works on my Win7 x64 Pro!
What program are you using? Step7 Manager, TIA, Step7 MicroWin?
What interface?
What interface?
Hi Sir,
I use Windows 7 Home & Step 7 v5.5
Does PG/PC Interface have support this Windows Version?
ReInstall Step 7 v5.5 and show your screenshotssingleperson wrote:Hi Sir,
You need MS Windows 7 64 bit Ultimate, Professional or Enterprise (Standard installation). STEP7 don´t support Windows home edition.
Really ?J0sa wrote:You need MS Windows 7 64 bit Ultimate, Professional or Enterprise (Standard installation). STEP7 don´t support Windows home edition.
============ How to Install your Step7 to Windows 7 Home Edition ===============
CD1\Setups.ini
Go to [OS] section
and insert ; before Win7x64Exclude and Win7ExcludeCode: Select all
Win7=1 ;Win7Exclude=SKU2;SKU3;SKU5;SKU8;SKU9;.... Win7Warning=SKU8;SKU9;SKU10;SKU12;SKU13;SKU14;SKU15;SKU16;SKU17;SKU18;SKU20;SKU21;SKU22;SKU23;SKU24;SKU25 Win7x64=1 ;Win7x64Exclude=SKU2;SKU3;SKU5;SKU8;SKU9;...
HI my friend,
I use cable USB --> RS485 to connect with S7-200. But it's not successful. ( Windows 7 Pro - 64bit)
I try to connect it in Windows XP. It works normally.
Please give me your advice. thanks
I think with Step 7 Microwin, should be used SP9 that ok with Programming. Because. SP8, Sp7... you can install but can't be programming.
But thank all about
Can be install but Programming be error.============ How to Install your Step7 to Windows 7 Home Edition ===============
CD1\Setups.ini
Go to [OS] section
But thank all about
