Hi to all,
I have one big problem with my S7Higraph project. When Compile the project I receive the error messages
I receive 14 errors messages and for each of errors which described as: “Check for missing “;” at end of line”, I have the sign “;” correctly at the end of line (you can see that on picture in attachment).
I don’t know what is wrong with, but obviously the line is correctly added in instruction. .
Ive contacted SiemensSupport and they told me that probably is problem in my project, but they have fixed this issue in their vesion V4.01:
This is from the link: https://support.automation.siemens.com/ ... viewreg=WW
Here is one question on the support forum from year 2005 – same problem which isn’t answered; https://www.automation.siemens.com/WW/f ... anguage=en
I can say only that they know for this issue and probably they fixed it in V4.01, but Im using V5.3 with SP1 - and probably they still have bugs in tool.
If anyone has experience with this mater and maybe some advice - I will be thankful for any comment.
