hello,
is it possible to communicate CP341 modbus RTU without dongle??
regards,
Ciwa
[?] : CP341 modbus without dongle
Re: [?] : CP341 modbus without dongle
No.
Dongle is VERY expensive. It is cheaper to buy S7-2226 and connect port 0 to S7-300 MPI, and use S7-200 port 1 as Modbus device, then buy a dongle for CP341.
Yes, it is possible , if you use VIPA CP341ciwa wrote:hello,
regards,
Ciwa
Hi jendy,
do you have full function library for modbus serial??
regards,
Ciwa
regards,
Ciwa
i use this version : http://holgerbischoff.onlinehome.de/html/modbus.html
it't compatible with PCD2 xx7 and Siemens S7 CP cards.
Difference with siemens modbus, this is without a dongle and only requires plc memory...
Info here: http://holgerbischoff.onlinehome.de/html/info.htm
i think you can request a demo version (which is a siemens protected SFC block) which can easily be reversed/unlocked....
monty
monty
Hi monty,
I prefer to xCP from Runmode http://www.runmode.com/xcp_modbus.html
if somebody have this library please share...
if you have use these software could you please share to me.
Regards
Regards
