Hi
Does anyone have this Solar Positioning Algorithm (SPA) for SIMATIC PLC S7-1200?
It is mentioned here:
https://www.automation.siemens.com/mcms ... fault.aspx
http://www.solarpraxis.de/fileadmin/use ... iemens.pdf
My guess is that the library has a PLC program and a HMI project, any information is welcome.
[REQUEST] Solar Tracking Algorithm for S7-1200
sanruku
BlackFlag
Re: [REQUEST] Solar Tracking Algorithm for S7-1200
I think you can get informations on astronomy sites. So you can find method to define equation for sun tracking and based on initial position of your installation you can achieve a sun tracking algorithm.
kassacsaba1986
Check OSCAT library
Check OSCAT library
sanruku
OSCAT library is only for Step7 v5, not for S7-1200, I'm looking for the S7-1200 tracking library.kassacsaba1986 wrote: Check OSCAT library
