Page 1 of 1
[LINK]: Com 521 Software V1.0
Posted: Tue Oct 12, 2010 6:13 am
by segaauto
I need Com 521 Software V1.0 or V1.1
Can somebody help me.
An advance thanks
Re: Request: Com 521 Software V1.0
Posted: Tue Oct 12, 2010 8:22 pm
by monty_burns_007
is that for the basic card CP521 BASIC ? (103U / 95U)
If so you can transfer the program to the CP through hyperterminal and put the card in run also there....
Posted: Thu Oct 14, 2010 3:01 am
by segaauto
monty_burns_007 wrote:is that for the basic card CP521 BASIC ? (103U / 95U)
YES it is for CP521 Basic....How can I transfer the program with Hyperterminal????? if you can help me I will Appreciate it a lot.
In advance Thanks.
segaauto
Posted: Thu Oct 14, 2010 6:52 pm
by monty_burns_007
connect to the 25pin serial port of the CP521 through a null modem cable (2 and 3 crossed).
put the CP521 in stop, if it is running, put the switch on CP521 in stop.
Then start and stop the PLC (run switch).
Open hyperterminal 9600 N E and press space.
You get a READY prompt.
Load you basic program through Hyperterminal File Send Text file.
After the program is transferred enter: PROG1
and then RUN
that's is !
monty :D
Posted: Thu Oct 14, 2010 7:32 pm
by Link
Hello ,
COM521 Basic V1.1 english,
you can download here: http://shareplace.com/?CFD358516
http://rapidshare.com/files/425088071/S5PEC21X.rar
Greetz
Posted: Fri Oct 15, 2010 5:54 pm
by segaauto
monty_burns_007 wrote:connect to the 25pin serial port of the CP521 through a null modem cable (2 and 3 crossed).
and then RUN
that's is !
monty :D
Hi Monty good day...thanks for your help but I have one more question how can I upload the actual program that is running in the module using Hyperterminal?????
Is there any list of commands to talk with the module using hyperterminal????
I really appreciate all your help and I hope to help you some day.
THANKS
Segaauto
Posted: Fri Oct 15, 2010 5:58 pm
by segaauto
Link wrote:Hello ,
Greetz
Thanks Corosop15 for your help.
My problem with this file is that it runs with versions lower than 7.0 of step5 and I have version 7.23.
I have been trying to get step 7 vesion 6.x but I can't find it.
Thanks a lot.
segaauto
Re: [LINK]: Com 521 Software V1.0
Posted: Fri Oct 15, 2010 6:49 pm
by Corosop15
Hello segaauto,
i have looked into all my archives, and i found 4 disks 3½'' with STEP5/ST for PC V6.03 and 3 disks 3½'' with STEP5/ST for PC V6.5 (Updating from V6.X).
It's running of old MS-DOS. I hope, the disks are o.k. If the disks are still readable, I upload it and you get a link for it.
Greetz
Corosop15
Posted: Fri Oct 15, 2010 8:54 pm
by Link
Hello
here is the link for STEP5 Versions 6.X (MS-DOS), that i have.
http://shareplace.com/?4A2F7BBB4
http://rapidshare.com/files/425356550/STEP5_V6.65.rar
Nice weekend
Posted: Sat Oct 16, 2010 6:03 am
by segaauto
I hope you are having a great day...
Thanks for this programs I'm downloading them and I will inform you tomorrow how was everything.
Thanks again
segaauto
Posted: Sat Oct 16, 2010 8:47 am
by monty_burns_007
i don't know if you can upload it back using hyperterminal.
But if the CP521 module is in stop : basic interpreter says: READY:
you can view the program with the basic LIST commando
maybe a copy paste action would do then :P
Posted: Sun Oct 17, 2010 8:32 pm
by segaauto
I put the module in stop mode and I followed all your instructions but it never say ready: and I can't write in hyperterminal there is only a cursor blinking but when I try to write nothing happens what I try to write is not showed. But every time when I press a key the led RCV in the module blink and looks like reciving something but nothing happens.
I you have any idea of what is happening I will appreciate any comment.
segaauto
Posted: Sun Oct 17, 2010 8:47 pm
by segaauto
I good day...
Thanks for the software i really appreciate it. Now my problem is that I can't install it because I have windows XP and the installer don't run.
I need to find a windows 95 or 98 in order to make it run or I don't know if there is a way to install it in windows XP.
Thanks a lot.
segaauto
Posted: Sun Oct 17, 2010 9:00 pm
by Corosop15
Hello segaauto,
The software COM521 and STEP5 V6.X versions only run under MS-DOS.
They do not work under Windows XP.
If you need MS-DOS 6.22, then I can upload it to you. All I have only a german version.
Greetz
Corosop15
Posted: Tue Oct 19, 2010 4:50 pm
by monty_burns_007
use a DOS or win95 vmware image....
Posted: Wed Oct 20, 2010 4:08 pm
by segaauto
monty_burns_007 wrote:use a DOS or win95 vmware image....
I good day...
how can I get th vmware and the images of dos and win95???
segaauto
Posted: Wed Oct 20, 2010 6:02 pm
by monty_burns_007
Here are the vmwares....
For Dos version of Step5 you only need the dos vmware image.....
Dos 6.22: http://rapidshare.com/files/332644479/V ... 2.zip.html
Win95: http://rapidshare.com/files/335395343/VM_Win_95.rar default password win login: 1234567
Posted: Thu Oct 21, 2010 6:46 am
by segaauto
Hi everybody good day....Finally I install step5 in dos.
I had to use VirtualBox and install a dos image and install step 5.
BUT here an other problem.... step5 is asking for a device that has to be connected in the parallel port in order to run I thing is a kind of electronic old Licence and as usual I don't know what to do.
Comments are welcome.
segaauto
