[?]: Comunication Plc with servo inverter thru profibus
jpavic
Post by jpavic » Tue Mar 30, 2010 6:31 pm
hallo!!!
Can someone explain to me or send to me some example (small program) how communicate PLC with the servo inverter thru profibus if you used SFC14 and SFC15.
I' now that we must used GSD file from servo inverter in Hardware connfiguration, and I' made hardware configuiration.
Then I' used address of servo inverter from hardware in program.
I' used PlC S7315 -2DP and servo inverter STOEBER 5000.
Thanks for HELLP.
Re: [?]: Comunication Plc with servo inverter thru profibus
Post by sania » Tue Mar 30, 2010 7:19 pm
i das not work with it,but try read it
http://www.stoeber.de/TDE/G5/DOKUV52/441687_0002.pdf
