Hy.
I have Siemens PLC S300.
He is connected to computer (which have Matlab and WinCC) with MPI.
I have PID control in PLC. The variable in PLC is in system memory. (For example Set point is type REAL and on location M4).
I have structure tag in WinCC on this location.
How can I read/write from/to this location with Matlab? I don't know from where to start.
[?]: Need help to connect PLC to Matlab
Scowl
Re: [?]: Need help to connect PLC to Matlab
May be OPC helps you. I know Matlab can use OPC for the communications.
Dreadnoult
MatLab OPC Toolbox -> OPC (Tag Managment->Add New Driver->OPC.chn) -> S7-300Scowl wrote:May be OPC helps you. I know Matlab can use OPC for the communications.
npopov
thanks for help.
